Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: dxf to pic ?
    Nov 2010
    dxf to pic ?
    I can print a acad drawing then scan it to make a pic. what is a simpler way to do this?
    hub
    hub is offline
    Sep 2010
    Finland
    http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html
    Nov 2010
    Quote Originally Posted by hub View Post
    could not get it to work
    hub
    hub is offline
    Sep 2010
    Finland
    Quote Originally Posted by kbenz View Post
    Its a "printer" kind of.. In autoCAD, select "plot" and then the "primo PDF" "printer". It will then ask you for a file name where to save.
    It has work fine for me for years, and it's free
    It works from any application as well.
    Sorry if I stated the obvious. I don't know your skill level.
    Hub
    Nov 2010
    Hub
    lol. my skill level is not there. I have autocad lt. still can't seem to get it to work. comes up as a .plt file
    May 2004
    I am not sure I understand what you are attempting to do. In Windows, with AutoCAD file open and visible, you can press the Print Screen key. Then open Paint and click edit - paste or press ctrl+V. Then save it in whatever graphic format you have available that suits your needs.
    http://www.kirkcon.com/
    Nov 2010
    Quote Originally Posted by txcncman View Post
    I want to convert a .dxf to a .jpeg.
    nothing happens when I hit print screen
    May 2004
    After you "hit" Print Screen, what happened when you opened Windows Paint and pressed the ctrl and the V keys at the same time?
    May 2004
    Here is a Print Screen screen shot of your last post. All done without special programs.
    Nov 2010
    oops. I was expecting something to pop up when i hit print screen. I saved it to my pics but it saved the whole acad screen. how can I just save the drawing it self?
    May 2004
    Now that you have it as a raster image, you can crop the image.
    In AutoCAD 14, you can use File - Export to save the drawing as WMF, EPS, BMP, or 3DS formats. I do not know if LT will do this.
    Nov 2010
    that worked
    thank you
  • Page 1 of 2 12 LastLast
