Hi Richard.
I would find another method for cutting your metal panel. I would not recommend using a router for this. Metal work generally needs slower speed than routers produce. If you want to cut sheet metal maybe draw your shape on the side panel & use sheetmetal sheers to cut out shape. Then clean up with a file. You could also try a jigsaw with a metal cutting blade to cut the shape out.
LinkBack URL
About LinkBacks
