I thought I would share with you a neat little project that I made at work on the cnc lathe this week. I guess I would call it a “Differential thread micro-adjuster Gizmo!” My company needed to make a test/calibration stand with a high degree of linear adjustment. Differential threads use two different thread pitches to obtain fine adjustment, this part has a 1”-28 ID and OD thread and a 1-1/2”-27 OD and ID thread, Both threads are right hand. Since 1/27th = .0370 and 1/28th =.0357 the difference between the two is .0013, which is the amount of distance this thing moves in 1 revolution! It’s pretty cool! The two threads offset one another except for the difference in pitch. On a clockwise rotation, it is pushing 1/28th while simultaneously pulling 1/27th. I attached a couple of pictures; assembled and disassembled…I’ll try to post more pics as the project progresses. Note that the 1” section can’t rotate because of the cap screws and slots. |
| Geof, That helped some, that was what I had in mind when I stated I was grasping the concept. Chuck, With regards to the piece with the slot/s, they hold it from turning as you mentioned but are the slot/s also the travel freedom ? Ken |
| Ken, All the slots do is to keep the center piece from rotating but still free to move along the thread axis, I guess they would also act as travel stops as well, although total travel is probably only 1/8" or so......Next week I'm going to make an support bracket for a .00005 digital test indicator! |
