Old 09-15-2005, 03:30 PM
MBG MBG is offline
MBG is on a distinguished road
license plate bracket (border)
Does anybody know on the luxury cars when you purchase them new from the dealer the brackets that go on the rear license plates. They usually have their logo on it and some seem to be made out out some type of metal.
Well.. I would like to make one. Does anybody know of what metal they use. It definitly has to be cheap and shiny. I am doubting it is aluminum or stainless.
Do you think they polish these metal or purchase.
Also the manufacturing of it. Do they mill it out of a solid block of metal or what?
please help.
Old 09-15-2005, 03:59 PM
JavaDog's Avatar
JavaDog is on a distinguished road
The cheap ones are just plastic, but on higher-ticket cars they are actually Aluminum. They aren't all that thick, maybe 1/8" or 1/4". They should be pretty simple to make, actually...
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Rekd's Avatar
Rekd is on a distinguished road
You could use Alum and have it chrome or nickel plated.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 09-15-2005, 04:01 PM
MBG MBG is offline
So aluminum is the metal of choice? Is it a solid block when they start off? Is there any other wya to make it?
Old 09-15-2005, 04:17 PM
Rekd's Avatar
Yep, typically metal or plastic. Usually made from sheet stock. You could, however, make it from bar stock and weld/bolt/rivet it together.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 09-15-2005, 04:20 PM
MBG MBG is offline
nah sheet stock would be the best. I know how to do it. I was just asking if there was any short cuts. How do you think they make it? Just machine like 100 of them out of sheet stock?
Old 09-15-2005, 04:22 PM
MBG MBG is offline
What about the lettering. I can engrave on my machine but how they get the letters black?
Old 09-15-2005, 04:24 PM
motomitch1 is on a distinguished road
I thought they were a chrome plated aluminum die cast part.
Old 09-15-2005, 04:31 PM
fastolds is on a distinguished road
I make my own for cars and bikes. I start with sheet stock, cut it out, powder coat it with a color of choice, then do the engraving so it sticks out better and finally put a coat of clear on it. I would show you the one on my bike but some find it offensive.
Old 09-15-2005, 04:35 PM
MBG MBG is offline
that would probably be the cheepest if they are doing production. Hmmmm.
  #11   Ban this user!
Old 09-15-2005, 04:36 PM
MBG MBG is offline
But , don't when you cast it you get that rough finish? I mean when I seen these before it looked like a machined surface smooth and either put in a vibratory or something. But I guess you could do the same with a cast product also right?
  #12   Ban this user!
Old 09-15-2005, 06:29 PM
Sand casting can be a little ruff
Die casting Die casted parts have smooth surfaces. Production is faster and labor costs per casting are lower.
