Is there any reason to choose one over the other in ACME 1/2-10 vs 5/8-8? The 1/2-10 rod (and nuts) seems to be a little more available than the others. What about other options too? Like 5/8-5 for example?
__________________ Gary Shepherd www.16tracks.com |
| If you were to put dials on the end of these, one would be graduated so that a full turn was 1/10 of an inch (100 thousandths), while the other would be 125 thousandths. So, if you were driving the axis of a machine, you might choose one over the other for convenience of counting the distance traveled. |
| I'm not "using it" for anything. Just wondering if there was good reason to choose one diameter/pitch over another for hobby CNC purposes. Would the 8tpi vs 10tpi possible allow faster rapids? Would the extra mass of the larger diameter cause a problem with stepper acceleration?
Fewer turns per inch gives more speed, but may require more power to get that speed. And the bigger the diameter, the more inertia, so the motor has more work to do to accelerate.
| By my math, going from 10tpi to 8tpi would give a 20% max speed increase. To do that, you'd have to go from .5" diameter to .625" which is a 25% increase in mass. Is all of this even worth bothering with? 10tpi seems like it could be very slow on a 2'x3' machine (or bigger).
| That's why everybody building routers uses 1/2-10 2 start, 1/2-8 4 start, or 1/2-10 5 start.
| Substituting ACME with Trapezoidal ("Metric" ACME) | rikun | Linear and Rotary Motion | 2 | 07-09-2009 04:39 PM |
| can stub acme be changed to acme | osiris999 | General Metalwork Discussion | 4 | 01-28-2009 02:00 AM |
| Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help | pandiyan.innova | CNCzone Club House | 7 | 11-16-2006 05:47 AM |
| Ab Acme Nut??? | MMT | CNC Plasma and Waterjet Machines | 0 | 02-27-2005 08:53 PM |
| what acme tap do I need for the Enco ACME rod? | AJ_Mac2001 | DIY-CNC Router Table Machines | 15 | 03-08-2004 07:24 AM |
