hi, guys i need your help. i am new to milling and i have some problems that i do not know what to do. i am trying to make cut a small lip around a 1/2" hole for an o-ring to seat abought 1/16 depth.i get so much chater that it ends up in a polygonal shape. my machine: optimum bf20 vario mt2 drawbar 10mm 20mm hss countersink hand tightened chuck no cooling aluminium 7075 i tried 70-2000rpms and i get the same. i also tried to form a side of a aluminium 7075 1/2" thickness with the side of a 3/8" hss endmill on a er25 collet and the finich is not good. it is shiny but there are noticeable waves. also tied low and high rpms (100-2000) what is going on? is there flexibility from the machine? i am asking too much from a small machine like this? thanks! |
| thanks! i will try that! my countersink is a 5 flute one.should i have bought the 3 flute ones? how slow speed do you mean? is there a way to measure the machine flexibility or rigidity? why i am taking a waving surface when miling with the side of a 3/8 endmil? what is the cause of this? thanks |
if its wavy, then it could be the hole is not concentric, work holding/rigidity issues. with 5 flute, you really need an aggressive feed rate. |
| i have a similiar problem with a 1/2" enmill cuting from the side a 1/2" aluminium plate. i get a wavy surfase with diagonal marks and i have tried speeds from 50-2500 and varius depths and rates. .i measure my spindle runout at the er25 collet body and there is a 0.01mm runout per revolution.if i remove the er 25 holder and measure it at the spindle inself there is a runout of 0.006 mm . my question is if this is normal and causes any kind of problems. as the endmil rotates i hear the sound changes in every recolution . is this amount of runout normal? thanks again!! |
| Keep it short, close to the spindle, low speed, aggressive feed, with a .5s pause before retract. 3 flute not good. Even flute count helps one side react against the other. Rigidity is everything.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Waviness in general is a sign of lack of rigidity. Could be the work holding, tool holding, gibbs, machine column, etc, etc. +1 on that! If all else fails you could try a 45* mill and circle it around as you would do if you were chanfering the piece's outside edge. |
| Help with countersink | gumba | General Metalwork Discussion | 6 | 07-06-2011 09:33 PM |
| Need Help!- Countersink Problem on CNC | Terry G | General Metalwork Discussion | 15 | 12-27-2010 07:54 AM |
| Looking for 90 deg. countersink to cut underside | georgebarr | General Metalwork Discussion | 4 | 11-01-2009 04:48 PM |
| 87 degree countersink | Rainbird | General Metalwork Discussion | 2 | 09-10-2007 01:07 PM |
| countersink 304 stainless | jprobst | Haas Mills | 18 | 06-16-2007 03:20 PM |
