Old 07-09-2011, 06:27 PM
RicknBeachcrest is on a distinguished road
I need a flat piece of aluminum bar
Greetings,
I am in the process of building a CNC router and one of the pieces I need is a flat piece of 3/8 in aluminum 3in X 7 1/2in. I bought a piece of some 6061 bar
Order Aluminum 6061 Rectangle in Small Quantities at OnlineMetals.com
Unfortunately it is slightly cupped. About 7 1/2 thou. Is there another type of aluminum that would be flat?
Thanks.
Rick
Name:	cupping 3 8 in.JPG‎
Old 07-09-2011, 06:41 PM
ger21's Avatar
Mic6, or cast tooling plate is dead flat. If you watch Ebay, you can probably find a small piece. I've bought a few that were about 5"x15", for about $15.
MIC-6 CAST TOOLING ALUMINUM PLATE 3/8" x 12" x 12" | eBay
Old 07-10-2011, 09:12 AM
Thanks Gerry,
It sure helps to know the name of things. I did a Google search and found this site. Looks like I can get just the size I need.
https://www.midweststeelsupply.com/s...FQFubAodLy3rZw
Rick
RFQ: Small aluminum piece grandmasterneil RFQ (Request for Quote). 6 03-21-2011 06:33 AM
Need A Quote- Flat aluminum piece near Edmonton AB youngjim Employment Opportunity 6 09-03-2009 01:41 AM
Need A Quote- Aluminum Piece Bartsimsonii Employment Opportunity 10 08-25-2009 08:10 PM
Milling AL flat on a piece that's too large for a vice. Cartierusm General Metalwork Discussion 21 08-22-2009 01:18 PM
Need A Quote- Turned aluminum piece raidfibre Employment Opportunity 5 02-19-2008 07:39 AM
