Old 07-02-2011, 09:25 PM
williamsmotower is on a distinguished road
removing material from carbide shaft.
I have a carbide shaft that is .385" dia. I need to remove .0005" from the dia.
Is there a special "sandpaper" that I can use, chuck my piece in the lathe and manually turn it down?
Any other suggestions?
Old 07-03-2011, 03:08 AM
Delw is on a distinguished road
wet dry paper will rub it off but not very fast and maybe only a tenth or 2.
if you can find some diamond lapping compound(paste) put it on a piece of wood and lap the carbide down.
A diamond file works better but wet it very good.
Trouble removing KM3 variable pulley from motor shaft Bkannry HURCO 3 04-25-2011 08:38 AM
removing shaft on 8x12 hf lathe ubaldc General Metal Working Machines 0 02-06-2010 10:12 PM
REMOVING CARBIDE CHIPS EMBEDDED IN TOOL HOLDER??? panaceabea General Metalwork Discussion 1 04-29-2009 08:55 PM
Removing R8 key from X3 Spindle shaft stag53 Benchtop Machines 7 04-23-2009 07:46 AM
Z axis shaft material andy_ck87028 Mechanical Calculations/Engineering Design 3 05-16-2005 07:46 AM
