Old 06-15-2011, 08:49 AM
REVCAM_Bob is on a distinguished road
side load on a cutter?
Does anyone have any formulas that will calculate approximate side loads on a cutter i.e. given feed rate, rpm, chip load, and material etc.?
Thanks!
Old 06-15-2011, 11:08 AM
fizzissist's Avatar
fizzissist is on a distinguished road
There are SOOOOO many variables......It is really more practical to follow manufacturer recommended feeds, DOC, chip loads, and speeds.
Just the helix angle alone can change the number by 50%.
If you wanted to be really ambitious, you could put a fish scale type force gage in your mill, linked between the spindle and table, gradually move the table with the pulse generator away and watch the gage display, meanwhile watching the load on the table's stepper. A series of measurements would give you an actual curve of force vs. stepper current.
Once you have that curve, you can put the mill in question in the spindle, and start taking some cuts in the mat'l in question with known variables and get some real empirical answers. You could even derive your own equations.
Me? I've just learned how to not break stuff. (at least not all the time)
Need Help!- Drifting X-axis, making step ladders one side whereas other side is smooth- SOS Khalid DIY-CNC Router Table Machines 13 07-13-2010 11:23 AM
Z-axis - mounting rails on spindle side, rather than tower side guru_florida Linear and Rotary Motion 7 01-31-2008 06:54 PM
Stepper Motor Belt Drive Side Load Question harryn Stepper Motors and Drives 3 08-07-2007 05:23 PM
mounting linear rails side by side 50062040 Linear and Rotary Motion 1 10-24-2005 07:49 AM
Left or right side cutter contour jfong FeatureCAM CAD/CAM 3 05-08-2005 10:35 AM
