Old 06-10-2011, 09:29 PM
MKMANU is on a distinguished road
Angry knurling keep double tracking/cnc
Hello All Im attempted to knurl on 321 SST
I have a range to finish the OD from 1.579-1.609
160DP diamond knurl convex knurl / straddle holder from accutrac .745 dia rolls L&R hand
Eurotech SLLY elite multi
feeding axial on Z
160 DP should roll .009..
Figure Id start at 1.583 and knurl to 1.590-1.592 RPM at 75 feed at .015
Ive adjusted +-.005 on blank diameter but still double tracking
I have had better luck on a swiss scew machine witha a single bump knurl than I'm having now..
Any tips?
Old 06-10-2011, 09:55 PM
fizzissist's Avatar
fizzissist is on a distinguished road
The diameters of the knurls are wrong, not the part.
Old 06-10-2011, 10:06 PM
the rolls are wrong? Only size that fits the holder I have .75..1.0 rolls for a 1.0 sq shank my machine holds 3/4
Old 06-10-2011, 10:59 PM
fizzissist's Avatar
Ok,
Assuming you're using 2 straight rolls, set at opposite angles for a diamond...
Carbide pins, properly lubed, no more than 50 SFM, and give it a good solid feed rate to get the rolls well engaged within the first revolution. You want to get on, and get off to prevent work hardening and flaking.
I mentioned diameter ... You want to make sure that the part diameter is a correct multiple of the pitch of the knurl.
Old 06-11-2011, 12:59 PM
djr76's Avatar
djr76 is on a distinguished road
try increasing feedrate, come in on 'X' then knurl on 'Z'
Old 06-13-2011, 12:27 PM
got it, took some adjust on the blank diameter..But after all my aggravation..The DP call out on the drawing is incorrect..should be a 96DP
Question - Job Tracking HiTech General Business Practices and Pricing 4 06-10-2011 09:38 PM
Need help with tool tracking DerbyCountyFan Haas Mills 1 02-08-2011 11:12 AM
Machine tracking problems gup Fanuc 0 06-19-2008 08:40 AM
Belt tracking proble BOBINETTE DIY-CNC Router Table Machines 21 02-05-2008 01:29 PM
Tracking tap life/wear mark.browne CNC Tooling 0 12-14-2006 04:55 PM
