Old 05-30-2011, 10:19 PM
zaebis is on a distinguished road
Need help fabricating parts... $$$
Folks,
Working hard on my hobby projects and luck would have it both my lathe and little CNC mill want to s##$%ts. Need help completing parts as my show time is quickly approaching I am afraid will not be able to finish my hot rods on time because of that.
If you are interested in a little $ on a side let me know or PM me.
Briefly I need 2-3 sets of 3 parts in each set. I have the stock and can send it to you or you use yours. At the very least I need 2 steel parts turned and 1 aluminum part milled (2.5D both sides) Equipment needed is CNC mill capable of 13x13 travels and better than a thou functional positioning accuracy and CNC or Manual well aligned lathe. And of course a skillful operator. I can prepare CAM output for your mill.
I will give details to those interested. I am in WA.
Cut well......
Old 05-30-2011, 11:52 PM
Shane123's Avatar
Shane123 is on a distinguished road
post the prints of the parts, might help us out on who can and cant handle the task at hand.
Old 05-31-2011, 01:26 AM
round ones are roughly 5" in diameter and the sticking out shaft has a taper. I need at least lathe work done on the round ones, circular hole pattern I can still manage with my handicapped equipment here.
Plate (aluminum):
is 12x12" and would have to be CNC milled on both sides.
surface finish doesnt matter but tolerances for hole centers and a bore in a center must be < 0.001. Also must be skimmed on both sides prior to milling to ensure parallelism of both surfaces. It is 1" plate but if it comes out to be thinner it is ok.
Round parts (mild steel).
Again I can live without holes but all lathe work needs to be done. Taper would need to be within 0.003 accurate other dimensions are even less critical. Since both round parts are shaft adapter for high rpm shaft, their surfaces will need to be dead on parallel.
ID:	135292   Click image for larger version
ID:	135293   Click image for larger version
ID:	135294   Click image for larger version
ID:	135296   Click image for larger version
Fabricating a steel rack justCNCit General Metalwork Discussion 11 06-21-2011 09:27 PM
Fabricating A 90° Gearbox twocik General Metal Working Machines 8 12-15-2010 09:31 AM
OnTarget Fabricating Inc - Need CNC Parts Cut? OnTarget Employment Opportunity 0 06-03-2009 01:10 PM
Is anyone here so good at fabricating they buy almost nothing now? slashmaster General Metalwork Discussion 5 03-29-2009 10:56 AM
Fabricating 80/20 blumpie 80/20, TSLOTS and other Aluminum Framing Systems 7 03-20-2008 05:23 PM
