I think you need to normalize your parts before machining.
You do not say whether it is cold rolled steel or hot rolled steel but whichever it is once you gas cut you introduce stresses from the heating and cooling. When you machine the parts these stresses slowly relax and distort the material.
For normalizing you need to heat the part to around 800 degrees C and then let it cool in air.
LinkBack URL
About LinkBacks
