Old 05-22-2011, 05:28 AM
jhovel's Avatar
jhovel is on a distinguished road
Another home-made power scraper
After reading lots about power scrapers here and elsewhere, I really liked the "sawzall" adaptation described in one of the past threads - that I can't find any more....
I needed to buy a cheap chinese reciprocating saw for a renovation job - and am unlikely to use it much in the future.
So I opened it up, modified the stroke down to 8mm (all reversible if needed) by drilling and tapping a new hole in the drive gear which produces the reciprocating action, and refitting the little needle roller bearing which drives the reciprocating slide.
I then made a scaper blade (more like a scraper 'lump' actually) from 3/4" mild steel, with a tungsten carbide strip brazed to one end. The fitting at the power tool end is a milled 1/2 wide slot, to get the blade facing the right way (unlike the previous builder who chose to hold the powertool on its side).
Since I have never used - or even seen - a Biax, I have nothing to compare my tool to. It works like a charm!
Pushed, it really makes the cast iron dust fly. Just gently held in position, it makes nice gentle scrapes, just as I would with my hand scaper. Only it is not exhausting and very quick. I use it at speed 2 out of 6.
I took me a little while to learn what angle to hold it at, so it doesn't jar my arm - and make gauges in the surface - and not skate across the iron.
It's pretty ovbious though and quickly learnt.
Anyway, here are a couple of photos of my effort:
Joe in Aus
Old 05-22-2011, 05:52 AM
toughtool is on a distinguished road
Joe,
That is a great idea, and just when the current Home Shop Machinist has an article about scraping. I will take a look at modifying mine and give it a try. I think I want to scrape bearing surfaces on some 3"X3"X1/4" steel tubing I plan on using for the X (and maybe) Y axis rail on my next CNC machine build. I'm currently using 1 inch (25mm) round crs but want something with less flex. Scraping 32 linear feet (four sides on two pieces of four feet long pieces) just for the X axis seemed daunting to me, since I haven't scraped before. Thanks for the idea. Joe
Old 05-22-2011, 06:23 AM
Karl_T's Avatar
Karl_T is on a distinguished road
Ditto, what an elegant solution. Thanks for the great tip.
Karl
Old 05-22-2011, 06:35 AM
jhovel's Avatar
Thanks guys!
Just remember, this is NOT my idea. I found it on this forum - I wish I could find the thread and acknowledge the right person. He copped a fair bit of flac from some members at the time.... but I thought it was an elegant solution. He machined a dovetail slide into the drive gear and made the stroke infinitely adjustable. I don't have the means to do that.....
Here are some of the photos which "made me do it" - that might trigger someone's memory so I can thank the original writer for his work:
ID:	134710   Click image for larger version
ID:	134711   Click image for larger version
ID:	134712   Click image for larger version
Joe in Aus
Old 05-22-2011, 04:23 PM
AFAIK is on a distinguished road
Is this the thread?:
Power scraping. Anyone tried to convert a Makita HK0500 for metal? - Page 2 - Practical Machinist - Largest Manufacturing Technology Forum on the Web
Pictures start on page 2
Old 05-23-2011, 05:44 AM
jhovel's Avatar
YES! That's the thread..... damn old age I woould have sworn I read it here....
Anyway, it was Mike (Holescreek) I have to thank! I'll post photos of mine in his thread to thank him...
When I finished reading the thread tonight, I noticed that he eventually reduced the stroke to 1/8" and found it better to control than the initial longer stroke. I'll try that next.
Here is a video link of him using his "Scaperzall":
Joe in Aus
Help me ID this power scraper.. AiR_GuNNeR General Metal Working Machines 0 03-13-2011 11:53 AM
Tormach home made power drawbar jakemestre Tormach PCNC 0 10-07-2010 01:34 PM
Home made Power Drawbar for BP CATCH22 Bridgeport and Hardinge Mills 2 03-02-2008 05:20 PM
Home made cross slide power feed for small lathe monte55 General Metal Working Machines 3 12-16-2007 01:30 PM
home made power feed on a sherline Rainman229 Mini Lathe 2 09-21-2004 11:56 PM
