Old 05-08-2011, 07:49 PM
bmurph is on a distinguished road
Rotary Table play
I have a 4" round of 4140 on a 4" rotary table, and when cutting the outside of the round the tables backlash causes a lot of noise, and vibration, and I think it's dulling the bits very fast. So I try to tighten the screw on the side that holds the table, but it's just not enough. Do I just gotta get a 6" table, or is there better quality out there?
Old 05-08-2011, 09:19 PM
HuFlungDung's Avatar
Moderator
That sounds like a pretty big part for a tiny table. You might have to take the table apart and find out if there is any way to reduce the backlash: reduce the end clearance between the worm and the housing, or move the worm eccentric so that the worm meshes closer to the worm gear. But bear in mind that a tiny table is going to exhibit more flexure than a bigger one, no matter how much you try to reduce the backlash.
Old 05-09-2011, 02:46 AM
Delw is on a distinguished road
Also check the lockdown system to make sure is really locking it down tight
Old 08-06-2011, 06:40 PM
hopefuldave is on a distinguished road
...And be sure you're not trying to climb mill - table rotation should move the work into the cutting edge (i.e. cutting on an outside diameter, if the spindle's clockwise from above, the table turns clockwise too - on an inside diameter the table would turn anticlockwise) - this ensures that the worm and wheel stay constantly loaded to take up the backlash.
Unfortunately the surface finish won't be as good as climb-milled *on a rigid setup*, but it sounds like it should be an improvement on what you're getting?
Just my ha'pennorth,
Dave H.
Play in Table strohkirchw Taig Mills & Lathes 2 12-31-2010 06:15 PM
Taig Mill Table "play/slop/lash" surrealism Taig Mills & Lathes 3 06-29-2010 03:54 PM
M32 VTC with rotary table jimiscnc Mazak, Mitsubishi, Mazatrol 2 02-17-2009 08:12 AM
Need Help!- Help with rotary table woodsnskins Benchtop Machines 5 12-18-2008 11:56 AM
Need Help!- cnc rotary table iccirvr Benchtop Machines 1 03-01-2008 11:05 AM
