Old 04-29-2011, 09:07 AM
CORBIN92087 is on a distinguished road
breaking taps in aluminum
Tap Size: 10-24
Material: T6 60601 Aluminum
Thread depth: .8 in
Pilot Dept: 1.125 in
Im using high pressure flood coolant and tapping pretty conservatively ( RPM 150 and Feed at 6.25 SFM 7.46) Im pilot drilling the recommended #25 drill and am still breaking taps. Im using a straight flute plug style tap.
Thanks for any help in advance
Old 04-29-2011, 10:42 AM
djr76's Avatar
djr76 is on a distinguished road
You're tapping to slow, try 25-60 sfm. sfm*3.82/tap diameter = spindle speed. Also peck tap it, and maybe use cutting oil to lube the holes.
Old 04-29-2011, 01:43 PM
hey thanks man. its working great so far!
Old 04-29-2011, 09:14 PM
fizzissist's Avatar
fizzissist is on a distinguished road
A spiral flute tap will help too by directing the chips up and out of the hole...
The 2 types of spiral give you chips up, or chips down, depending on the direction of the flute's helix.
....Make sure the holes are CLEAR OF CHIPS before running the tap in, especially with a straight flute tap.
You should be able to run that tap at 800-1500 rpm all day long with a good quality coolant.
Need Help!- Keep Breaking Taps behindpropeller Haas Mills 16 01-21-2012 09:16 AM
Need Help!- Breaking 0-80 Taps..... nfrees114 General Metalwork Discussion 7 12-01-2010 10:46 AM
Need Help!- breaking taps!!!!! dieman1968 Mazak, Mitsubishi, Mazatrol 8 04-01-2009 04:06 PM
Breaking Taps? tricmachine General Metalwork Discussion 2 01-13-2009 01:22 PM
Problem- Breaking 6-32 taps CNCMike General Metalwork Discussion 9 12-05-2008 03:27 PM
