Old 04-28-2011, 11:05 AM
BanduraMaker is on a distinguished road
Source for small diameter partially threaded rod.
This is kind of a longshot but I thought I'd cast the net and see what I can find.
I'm designing a re-tuning mechanism for my instruments and I'm going to require partially threaded rod to complete the design. The rod is of a very small diameter which is making it quite hard to find. I'm still in the early stages of design so I have some flexibility of dimensions. Here's what I'm looking for:
Diameter - at least .075" but no more than .1" (I'm thinking that .08 would be ideal)
Length of thread - minimum .250" a little more would be better
Length of smooth part - minimum 1"
Pitch - looking for as high a TPI I can find. This thread will be used for final intonation so more is better.
The threaded portion major diameter can be either the same as the smooth portion or a slightly greater diameter (like on a stud). I'm also willing to machine the parts e.g. if I could find a threaded stud that could be made to fit my parameters after machining.
I've found small diameter fully threaded rod that could fit the bill if I could machine the threads off and have a smooth shaft when I'm done. I don't know how I'd hold the part while machining though and how I could hold a tight tolerance on the shaft. If someone has ideas, let me know.
The final option would be to thread the rod by myself but, I imagine that it's not easy to thread 54 to 80tpi without some sort of special fixture. I'm getting my CNC gantry router within a few days but I don't know, is it possible to thread something that small with that high a TPI with a stepper controlled (gecko 540)?
Any and all advice is greatly appreciated.
Old 04-28-2011, 05:48 PM
kregan's Avatar
kregan is on a distinguished road
Try DU-BRO hardware.
Lots of small threaded rods and such for R/C planes and boats.
Du-Bro RC - AIRCRAFT, PUSH RODS/ACCESSORIES
Old 04-28-2011, 06:29 PM
packrat is on a distinguished road
How about using bicycle spokes? The end with the threads(rim end) would do the job, and the nipples can be modified if you need nuts. Spokes come in different diameters also.
Old 04-29-2011, 10:48 AM
djr76's Avatar
djr76 is on a distinguished road
you can try Mcmaster-Carr or search for hobby stuff like rc cars, and air plane sites, they use lots of small diameter partially threaded rods.
Where to buy small diameter corner rounding end mills? Doxs Want To Buy...Need help! 3 04-03-2011 02:52 PM
Source for precision or fine threaded rod in short lengths? nadsab Work Fixtures and Hold-Down Solutions 1 03-12-2011 12:31 PM
Need Help!- source for larger diameter timing pulleys MMTechi Want To Buy...Need help! 2 04-28-2010 09:28 PM
Need A Quote- RFQ - Custom Partially threaded socket head screws in stainless - 1000 pieces RECustom Employment Opportunity 7 01-29-2009 12:35 AM
Diameter of inside cut, too small SVM General CAM Discussion 16 06-19-2006 09:17 AM
