Old 04-27-2011, 09:05 PM
buffaloguy is on a distinguished road
need help with 2.375" w/ 11.5 tpi on a pipe
Looking for some insight on what codes people would use on 11.5 threads on 2.375 O.D aluminum.
Old 04-28-2011, 12:42 AM
Delw is on a distinguished road
What do you mean codes?
just throw a threading cycle in it if you have a lathe or helical interpulate it if your doing it on a mill. doesnt make any difference if its alum or stelite you still have to have the lead
1/11.5 = lead ie the number you put into the code to get the thread.
Old 04-29-2011, 10:56 PM
NewToGibbs is on a distinguished road
Is this an NPT thread? What machine/control are you gonna use?
Old 04-30-2011, 08:35 PM
NPT. I should have mentioned that in the post. Using a Doosan 200 w/ fanuc controls. I used some numbers I had ona previous program and just changed the starting point.
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
? 1" schd 40 pipe to make wood cutting tools ? sailandoar Hand Tooling 3 07-07-2008 05:58 PM
gas pipe or hot/cold water pipe? jaymed2000 JGRO Router Table Design 2 03-15-2008 09:01 PM
emt conduit, galvanized pipe or black pipe? JohnG DIY-CNC Router Table Machines 5 05-21-2006 08:24 PM
