Old 04-21-2011, 10:50 AM
blackc1 is on a distinguished road
Tapping KOVAR
I need to hand tap 1-64 unc 3b threads in kovar. Sources for kovar info mention that the material has a tendency to flow back into the hole when tap drilling so i am using a #52 size tap drill which is .001 in dia. larger than the standard tap drill for a 1-64 thread. Can any one tell me if my plan is correct or have any other tips please let me know.
Old 04-21-2011, 11:39 AM
WayneHill's Avatar
WayneHill is on a distinguished road
I do not have experience with Kovar.
Have you tried using a form tap and bees wax?
The tenancy of the material to flow back in the hole is similar characteristic to stainless steel.
Wayne Hill
www.codemangler.com
Old 04-21-2011, 12:26 PM
fizzissist's Avatar
fizzissist is on a distinguished road
Yuck.
Assuming this is where you got the back-flow info??
High Temp Metals 800-500-2141 - Kovar Technical Data
They recommend a coolant with "fatty esters"....which reminds me of how well 1/2 & 1/2 works when tapping copper...
I'd go with the largest tap drill you can get away with for the min. % thread, and the smallest H# available in that tap size.
I've found that OSG or Emuge taps have performed the best for me in very small sizes.
Old 04-22-2011, 05:58 AM
taylors is on a distinguished road
I just ran a bunch of kovar parts with 0-80 threads. One thing I do with form tapping is run my coolant really rich up around 12-15%. And yes it shrinks back just like titanium. But i ended up injecting Moly-dee into the holes with a syringe before tapping. It worked great.
Old 04-22-2011, 09:59 AM
fizzissist's Avatar
Not in kovar, but in 304L, did essentially the same thing. Turned off the coolant, blew all the holes out, then just before the tap went in I brushed on the Moly-dee with an acid brush. (gently, so you don't get hair in it.. )
One thing I found was that using a good quality metric drill (I think it was a .055", or 1.40mm) gave me a lot of comfort, as well as lots of holes, and they gaged in spec. Have done hundreds of blind 0-80's that way. Love them formers!!
Kovar Machining ndorin General Metalwork Discussion 1 01-28-2011 12:57 PM
tapping on a mini mill without rigid tapping??? mls Haas Mills 13 07-03-2009 06:43 PM
Tapping head or rigid tapping Gregory_C Syil Products 2 10-18-2008 12:49 AM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 12:08 PM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 08:10 PM
