Old 04-14-2011, 06:52 PM
snovak240 is on a distinguished road
Tapmatic NCR-OA adjustments
I am trying to figure out how to adjust the tension on this NCR-OA tapping head. It says it is adjustable for 4 thru 1/4 & M-2.5 thru M-6 taps. I am using a 6-32 but dont know how to lighten or even adjust the tension. Can someone help! Thanks
Old 04-16-2011, 01:40 PM
JimBoyce is on a distinguished road
Check the knurled cap on top that is the same diameter as the body. This turns in relation to the body to adjust the tension. If the tension is set to max, it may be hard to turn for the first few turns. Make sure the locking set screw is loose before turning.
Tags
tapmatic tapping head, tapping, tension adjustment
Need some to make adjustments to post hd4684hg Post Processor Files 2 12-19-2010 03:18 AM
HF 7X10 Runout Adjustments eartaker Mini Lathe 5 08-08-2010 01:20 PM
Knife adjustments on shear hmc710 General Metal Working Machines 0 02-28-2008 07:59 AM
Mods, adjustments & tweeks for the X2 Brass_Machine Benchtop Machines 1 01-23-2007 05:04 PM
Pot adjustments on amp board -Luke- Fadal 1 05-10-2006 11:15 AM
