Old 04-01-2011, 10:11 AM
wally188 is on a distinguished road
Custom milling on Aluminum
Hey guys,
This is my first post, so be gentle
I dont know a lot about machining so i need some advice please.
I have a block of metal (aluminum) i want to have cut down to some exact specs. It will includes very detailed scrollwork (etchings).
I am unsure how to do this. I called a waterjet company and he said they could only make straight cuts and not do any engravings with it. He said to use a saw then polish it down. Then maybe have a laser for engraving? Is this correct?
I am trying to make a prototype of thehead part Thor movie hammer. I will be through with the 3D Cad file today with all the specs. I am attaching a few photos to give you an idea of what i am trying to do with an 8.5"x5.5"x5" block. It already has basic dimensions of what i want. One of the photos show detail work on side engraving.
Thanks for any assistance.
ID:	130485   Click image for larger version
Old 04-01-2011, 10:22 AM
Delw is on a distinguished road
any 3 axis cnc mill should do what you need just fine. as far as the scroll work again you need a 3 axis mill and a decent cad cam program. the engraving on the top same thing 3 axis mill.
Newbie- CNC recommendations for milling custom stainless steel guitar hardware? Corvus Musical Instrument Design & Construction 1 03-25-2011 06:20 PM
Need Help!- Custom built .063" aluminum sheet polisher. diyengineer Mass finishing equipment/media/stratigies 8 05-04-2010 07:56 AM
CUSTOM PIN GAGES needed... 6061 Aluminum, 26.5mm - 60mm by .5mm increments.. squale Employment Opportunity 17 01-15-2010 02:52 PM
RFQ - Aluminum Milling Axiom Employment Opportunity 15 03-05-2007 10:29 PM
Anyone want to do some custom Milling work?? mrbaseball JGRO Router Table Design 2 10-21-2005 05:33 PM
