Old 03-29-2011, 11:49 AM
wmpy is on a distinguished road
reaming vs. boring steel alloy
Hi. I make a bunch of various sized gear blanks on a CNC lathe from either 9310 or 4140. Average bore size is about .188, and I need to hold .0005" tolerance on that bore. I've been making the parts using solid carbide boring bars. When I make a job out of 4140, I can usually make about 2000 parts without having a single part undersize on the bore. With 9310, it's a different story. I'm always struggling to keep the bore size off the bottom. My best results so far are with a brand new TiN coated tool, but once that tool starts to get just a little dull, the bore size starts closing up on me. I originally tried reaming with a HSS tool, but that was awful. The material just welded to the tool and cut oversize or tapered right away. I was using oil, by the way. Anyway, I'm wondering what you would do? I'm fine making the 4140 parts, but with the 9310 should I stick with the boring bar and just keep sharpening / changing bars frequently, or should I go back to reaming? Maybe trying a coated and/ or carbide reamer? Thoughts?
Old 03-29-2011, 12:56 PM
mc_n_g is on a distinguished road
What state is the 9310 in? Is it getting hardened after your operations?
Are you running the reamer at least 1/2 the speed of a HSS drillbit? The only other thing I can think of is you should only be cutting about 0.010" to 0.025" with the reamer (meaning the hole should be undersize by 0.010" to 0.025" before reaming).
Old 03-29-2011, 01:07 PM
The 9310 is annealed, and yes, it gets hardened after my operations. I don't remember exactly, but I believe I was leaving about .010" for reaming and running it about 40 sfm.
Old 03-29-2011, 06:41 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Have you had any success reaming any type of material on said machine?
DP
Old 03-29-2011, 10:58 PM
Actually, no, I don't think I have ever reamed on this machine. I much prefer to bore when I can. If you're thinking that the machine might be out of alignment... it's a gang-tool lathe, so I aligned the holder with an indicator to be in line with the spindle. I tried holding the reamer rigidly and also in a floating holder. No luck.
Old 03-29-2011, 11:24 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
best bet would most likely be a solid carbide reamer that is dialed in dead nuts
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 03-29-2011, 11:29 PM
I think I'll try that. Do you recommend a floating holder? or holding rigidly?
Old 03-30-2011, 07:59 AM
dertsap's Avatar
Gold Member
rigid and dialed in dead nuts
Old 03-30-2011, 09:07 PM
I think your reaming speed is at the low end of recommended drilling SFM. I think you are reaming too fast for HSS is low carbon. I would say 10-15 SFM for the HSS reamer rather than 40 SFM in that material. You might be smoking the reamer and forcing the galling.
Need Help!- 3.9 H7 Reaming in 58 HRC SAE8620 steel yaji63 CNC Tooling 0 03-18-2011 11:31 PM
Engraving 1mm on Alloy/Steel SAE1020 lucas schneider Laser Engraving & Cutting Machines 10 10-19-2010 08:25 AM
Newbie- Tormach and Alloy Steel ? Need CNC Tormach PCNC 7 03-06-2009 09:34 PM
C-300 alloy steel 5th-axis General Material Machining Solutions 0 02-20-2008 09:17 AM
Is chrome-moly considered alloy steel? Cowbell General Metalwork Discussion 12 02-03-2006 06:27 PM
