I am trying to repair a wobbler flat area. It requires 0.8 surface finish and 0.32 parallel The depth of the flat area is 700mm. See the attached picture for details. I have CNC milling and boring machines with multi axis. Milling head will not fit inside this. Spindle with Dia 180 can move upto 1000mm. Any ideas on machining this component |
| First what is a woubler? Could you use a right angel head on a Vertical mill . wounder how the part was made in the first place? EDM, Broch,Shaper? How precision is the finish need to be could you weld and grind by hand or grind with a toolpost grinder or the head from a small tool and cutter grinder mounted on the ram of a manual mill? Improvise and imaganation Kevin |
Thank you very mush for your reply. It is used in machines and motors for providing a constant drive speed for a shaft during variations in the speed of rotation of the power delivered to the wobbler housing. It requires a perfectly flat control surface to control the speed. Now this unit has a worn out area at flat surface. This will be welded to build up the material and then machined to get the desired dimensions. Earlier, a small milling head was used on horizontal boring machine but the surface finish, flatness and the parallelism between the surface are not good enough. I am looking for any other ideas to machine this item. I have received this item in a worn out condition and could not make out how it was manufactured first time. |
| Repairing G540 ? | blue_luke | Gecko Drives | 5 | 10-28-2010 08:08 PM |
| Vintage wobbler | stevehuckss396 | Steam Engines | 1 | 11-17-2008 08:45 PM |
| Twin Wobbler | JOE65 | Steam Engines | 4 | 08-17-2008 11:40 AM |
| Wobbler Questions | dragons_fire | Steam Engines | 12 | 06-07-2007 12:35 PM |
| Table Repairing | Chris64 | General Metalwork Discussion | 7 | 08-30-2006 06:56 PM |
