Old 03-15-2011, 04:33 AM
StalkDaddy is on a distinguished road
Rigid Tapping
I have never really had the need to tap before using our Haas TM1 mill, but we have a job in right now that had 25 tapped holes and I do not want to do all of them by hand. Since the machine had spindle orientation and rigid tapping appears fairly simple with our programming software, I thought I would have a try at it. My only question is if I can use a standard straight fluted tap for this operation or if I need something different. Seems to me they could break easily. Any advise?
Old 03-15-2011, 12:45 PM
yoshi900 is on a distinguished road
material? thru hole or blind hole? how deep?
Old 03-15-2011, 02:56 PM
The material is 304 stainless, 1/4-20 thread tapped 1/2" deep. We also do a lot of aluminum stuff as well. If I start doing this, i might as well apply it to other stuff we do as well.
Old 03-15-2011, 03:23 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Would be inclined to add .2mm to the core hole diameter as stainless tends to close up on the tap.
A spiral flute may be better for blind holes but you will still need to keep tap and holes free from stray swarf and I have found them to be less reliable on tight tolerance threads.
There is also the option of roll tapping, which due to the larger core size required, is probably safer breakage-wise (and no swarf to rip up aly threads) but again, not that great if you need a tight tolerance thread.
DP
Old 03-15-2011, 05:22 PM
Jawno is on a distinguished road
You might consider a tapmatic too.
If your going into a blind whole you'll probably want to give yourself a couple tenths of hole beyond the end of the threads so the machine has time to slow down and reverse.
I second the previous info.
Exotaps work well for us.
Good luck.
Jawno
Old 03-15-2011, 05:55 PM
underthetire is on a distinguished road
Some coolants don't like tapping in 304 either. You might have to mix heavy, or apply tapping fluid by hand.
Old 03-15-2011, 07:11 PM
Shane123's Avatar
Shane123 is on a distinguished road
i hate tapping in 304, and the 1/4-20 tap is usually weak and snaps easily in it. drill oversized by .003 or .004 if possible, and try peck tapping. if your controller don't support peck tapping, just program it to tap the same hole at different z depths. by the way, i hate tapping 304.
Old 03-16-2011, 12:57 PM
Cruiser is on a distinguished road
We had a series of parts to thread that had an unforgiving tight thread tollerance. The matr'l was stnls & inconel. After much head ache it was finally decided to mill the threads and throw the cutter away and replace it after x number of holes. It became very reliable once we knew how many holes was safe to do before changing cutter. When cutting tool was selected, we opted for the best tool that was available, period !
Don
IH v-3 early model owner
Old 03-18-2011, 03:20 PM
5axisguy is on a distinguished road
Do not use a floating holder for rigid tapping. Tap must be in a collet or milling chuck, tight!
tapping on a mini mill without rigid tapping??? mls Haas Mills 13 07-03-2009 06:43 PM
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
Tapping head or rigid tapping Gregory_C Syil Products 2 10-18-2008 12:49 AM
Very rigid tapping Vern Smith Haas Mills 55 06-14-2007 05:52 PM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 12:08 PM
