Old 03-15-2011, 12:20 AM
The_Tuner is on a distinguished road
Arrow Kool Mist #77 proper mixture for flood
I have read numerous posts of this stuff causing rust, read as many said they get no rust of their machine's as well ... I live near Pittsburgh PA ... we have city water and its deemed as hard water here ... wondering if anyone else uses this for their flood coolant and what ratio's they use and do you use tap water or distilled water ... it says mix 32:1 (4 oz per gallon of water)... read some people mix up to 8 oz to a gallon and that solved any problems ... I just don't want to waste it if not needed.
I have not yet mixed this or used this, just wanted an informed opinion before I get to using it.
Koolmist says its product #77 and #78 is suitable for Flood and Mist ... again I am using it for flood coolant, perhaps may put some in a spray bottle as well for quick jobs when not using flood.
Thanks for any replies
Old 03-19-2011, 11:54 PM
An update on this since I got no replies perhaps this could help someone else.
I ended up just mixing it 8 ounces per gallon of tap water instead of the recomended 4 ounces per gallon, I had read someone else had problems but after they did this there was no more problems.
A few nights ago I was milling aluminum with flood, it was in the evening and went into the house to eat dinner and somehow fell asleep like a goof, woke in the morning and was like hell the mill was left all covered with shavings and wet ... well went in and everything was dry and no stains or rust of any kind.
Mist vs. Flood coolant rogerfries Bridgeport and Hardinge Mills 21 08-13-2010 03:17 PM
Coolant, Flood, Mist, WD-40, etc Smitty911 Benchtop Machines 37 11-15-2009 09:15 AM
Flood and Mist controls shane.vella Machines running Mach Software 1 10-01-2008 05:56 PM
Refractometer Value ? Kool Mist #77 Rich05 General Metalwork Discussion 1 06-24-2008 03:58 PM
Kool Mist coolant, opinions phantomcow2 General Metal Working Machines 6 11-10-2005 06:18 PM
