Old 03-14-2011, 10:52 AM
ARVADEST is on a distinguished road
Want to get rid of costly weld nuts or inserts?
Have you ever heard of a process called Thermal drilling?
Thermal drilling is a process that uses friction to produce bushings in metal tubing and flat stock.
The combined rotational and downward force of our special Thermal Drilling tool bit creates frictional heat. Temperatures can reach 900 C for the tool, and 700 C for the work piece.
The material is transformed into a "super-plastic" state, allowing the tool to displace material and form a bushing. The height of the bushing is roughly 3 to 4 times the original metal thickness.
These bushings are ideal for threaded applications, as the number and strength of threads is significantly increased. It is an excellent alternative to weld nuts or threaded inserts. The bushing can also be used as a support hole for welded, soldered or brazed connections as well as for a load-bearing surface.
The Thermal Drilling System can be used in most ferrous and non-ferrous metals including mild steel, stainless steel, copper, brass and aluminium, with material thickness up to 12 mm. In general, all malleable materials can be thermal drilled.
Tags
flow drill, flowdrill, flowdrilling, form drill, formdrill
leadscrew nuts and half nuts jayhawkman EBAY ADS 0 11-07-2009 01:00 AM
Do I weld or glue? andy_ck87028 Mechanical Calculations/Engineering Design 8 10-08-2005 06:10 PM
JB Weld question lurch Welding, Brazing, Soldering, Sealing 6 08-14-2005 02:18 PM
Nuts are driving me nuts! Cold Fusion CNCzone Club House 9 06-12-2004 11:40 PM
Nuts; I'm thinking about my nuts Stevie General Metal Working Machines 11 02-28-2004 05:55 PM
