Old 03-09-2011, 02:55 AM
Lugy is on a distinguished road
Machining 2mm alu plate
Hi folks, today I'm attempting to machine up a lid as part of a job we're trying really hard to get.
The lid is made from 2mm (.080") 6082 - this is the finished size, and has pockets 1mm (.040") deep, see the attached screen shot showing completed part.
The first method I tried was to just carpet tape the part to a fixture, then machine the part complete, the profile worked easy enough, though it went wrong on the pocket.
Next, I carpet taped the blank to the fixture again, drilled the holes and screwed it down all round the profile before trying the pockets, this was better, but the finish on the pocket was terrible and the part began to vibrate.
The material would also appear to be quite chewy, almost like 5251 (IIRC) which doesn't seem to help much. Especially as I'm not using coolant (when I tried using it, the tape lost it's stickiness!).
The I'm using a 6mm 2FA type slot drill at 10krpm and between 200-300mm/min.
Any suggestions to help me would be greatly appreciated (except a vac table, we can't afford one of them ).
Lucas
Old 03-09-2011, 04:44 AM
nickswimsfast is on a distinguished road
I'm by no means an expert, but will throw a few ideas for you to try.
If the part is vibrating than you are near a natural frequency for your setup. If you can afford to decrease or increase the RPMs of the spindle, you might be able to get out of that response frequency.
You've probably already considered this - but are there any features that go through the whole part which you could use to clamp? Could you ask your customer for a concession of a new feature for clamping in the middle? Sometimes engineers are focused more on the design and can overlook some of the requirements of manufacturing a part. Good design/manufacturing communication really helps.
Another option would be to simply clamp a bar across the lid with a bar as shown in the picture. Make sure your CNC program clears the fixture bar. Obviously you could get more complicated with a clamp like this.
Would the stars shine if nobody were there to observe them?
Old 03-09-2011, 06:10 AM
chuck5121 is on a distinguished road
A vacum table would be good if you don't have to machine through the work piece. A second option would be to machine a thicker piece with your profiles machined through then clamp it on top of your work piece. Good luck
Old 03-12-2011, 08:03 AM
Ed from NY is on a distinguished road
you could try clamping 5-6 blanks at a time, doing a few pockets, clamping the set again thru the pockets and machining the profile and whatever is left. If it still vibrates you could try machining the same piece in steel plate, but with a slightly smaller diameter and larger pockets so to use that on top of the pile to help clamp everything down -- kinf of a sandwich. if you have a lot of these to do you could add some aligning blocks to that plate that partially fill the pockets to save you some time in aligning the features done in the two passes. Good luck!
Old 03-12-2011, 10:38 AM
underthetire is on a distinguished road
Really looks like a perfect vacuum table part. Don't know about Scotland, but here we can get little vacuum pumps at places like harbor freight pretty cheap. The fixture woul be simple enough.
Need Help!- Machining AR400 steel plate cybeeria General Metalwork Discussion 2 11-06-2009 04:05 PM
Need Help!- machining armor plate DELO Metal Working Tooling 1 11-22-2008 01:44 PM
machining brass plate woodman08 Gorilla CNC Machines 0 10-28-2008 12:21 AM
Help machining C260 brass plate. 68rustang General Metalwork Discussion 4 08-03-2007 02:34 PM
thin plate machining tmt_92021 General Metalwork Discussion 14 10-23-2006 07:54 PM
