Old 03-06-2011, 10:00 PM
scheek's Avatar
scheek is on a distinguished road
Cool Cut 1st pc if aluminum
I just cut my first pc of aluminum. It was .25 and I was cutting out a 10" wheel. My setup was about .3 mm increments and 8 inches a minute. I used WD-40 as a lube. From what I could tell the chip was okay. With a DYI-CNC I didn't want to push anything.
Is this about right for speed. I think I was running about 8-10K rpm. Too, how will I tell if my .25 mil bit is going bad?
Old 03-08-2011, 04:37 PM
scheek's Avatar
Cool Summary of my first .25 aluminum cut
This is just for anyone cutting their first aluminum stock. I successfully cut a 10" wheel out of .25 plate. I did change to a HS bit-single flute. It cut smoother. However my 4 flute did well too.
My table top is fairly close but when I screwed my aluminum plate down in three places, I realized that my first pass was not hitting the surface everywhere. On the second pass it did.
What I learned was that I need to slow the machine down on that first pass so the bit avoids biting too deep in any surprisingly non level areas. Once the router made a good revolution and I was getting good chip, I increased the Feed until I was comfortable.
I never increased more than 12 inches/min and I did that on the last few passes. I ran most of the job at around 9 with a 12000 rpm.
I probably am using 6061 aluminum, not sure, but it did cut good. I understand from other post that 5000 get hard.
Anywho, that is what I did and happy.
80/20 aluminum gantry, milled aluminum ends 3Dsigns DIY-CNC Router Table Machines 11 10-15-2010 03:55 PM
Securing Aluminum to Aluminum webgeek General Metalwork Discussion 3 12-29-2009 05:30 AM
Bonding aluminum to aluminum - Doable? How? Arquibaldo General Metalwork Discussion 15 11-05-2009 09:01 PM
Carbide endmills Aluminum vs non-aluminum ??? zaebis General Metalwork Discussion 7 09-14-2009 08:53 AM
pressing aluminum into an aluminum tube Fishin_Rod Mechanical Calculations/Engineering Design 24 07-01-2009 12:23 AM
