Old 03-06-2011, 09:06 AM
sethren is on a distinguished road
thread depth
Can anyone tell me please what the thread depth, ( core depth ), is on a 5 inch diameter @ 12 tpi ?
Is there a formula ( i know there is ) its just such a rare occurence that I need to use it that I have forgotten it or how to obtain it !
seth
Old 03-06-2011, 10:03 AM
Google is your friend. This is one of the links that came up when I Googled "thread depth calculation".
Stop Scratching Your Head and Make Some Chips !!
Scroll almost to the bottom of the page.
Old 03-06-2011, 11:51 AM
thanks Geof. Do you think that threr's much difference between the 60 degree angle, given, and the 55 degree that I want ?
the 60 degree is metric i think and i want imperial.
seth
Old 03-06-2011, 02:38 PM
Whitworth is 55 degrees (I think) but UNC and UNF are both 60. I did a rough calculation and I think the difference will be around 0.002" to 0.003" so I figure you can probably ignore it.
Old 03-06-2011, 03:36 PM
Some threads are truncated or have radiused "peaks and valleys" as well.
Dick Z
DZASTR
Old 03-07-2011, 02:33 AM
Smile
Yes Geoff your right. Thanks for that.
Seth
Old 08-09-2011, 10:42 AM
GAGV is on a distinguished road
feed rate to make a thread
Hi, please i need your help, i need to make a 10-24 and 3/8" NF thread, and i need to know feed rate and spindle speed, i will work in A380 alluminium and stainless steel
thanks
Old 08-09-2011, 11:43 PM
Shane123's Avatar
Shane123 is on a distinguished road
thanks
this would have been easier to get replies if you had started a new thread. your feed on a lathe will be IPR, so take 1 divided by the number of threads per inch, and that is your feed (example 5/16-24 thread would have a feed of .0416 per revolution, aka F.0416). as for speed, I usually start off around 1500 rpm, unless there is alot of part hanging out from the spindle, then i slow it down to resolve chatter & keep tool life, when using inserts. if your using a tap, slow it down to 150-500, depending on material and how well you trust your spindle/turret coordination.
Max Cut depth WilliamWoodWork WoodWorking 2 10-05-2010 10:46 AM
Need Help!- Thread spec for camera lens filter thread cmays General Metalwork Discussion 3 08-22-2010 01:14 PM
Problem- Metric thread depth surfit General Metalwork Discussion 4 03-20-2010 06:50 PM
acme thread combos and thread mixing calaber40 Linear and Rotary Motion 5 05-15-2009 08:04 PM
Thread mill external NPT thread cutting edge General Metalwork Discussion 11 09-15-2008 08:33 AM
