Old 02-28-2011, 07:16 PM
777funk is on a distinguished road
What's the best way to Mark the Home Location on a Fixture?
I have several machining fixtures for my processes. They are located to the table of my machine. I'm looking for a way to permanently (well as permanently as possible) mark the home location on my fixture plates. That way if something ever goes off in either the fixture or machine I can adjust.
What brought this about is that I had to remove the servos on my machine today and when I put them back on my indexing position home was of course no longer the same since the motors were removed and the encoders or ball-screws had turned. Back together and... no line up. Home was off in the X and Y directions.
So I'd like to avoid this in the future. I want to have a sure fire way to ALWAYS make sure I can get my home back every time.
I have a home spot plunged into my fixture plate but when I re-aligned the ball-screws and encoders I just did it by eyeballing the tool and rotating the ballscrew until the tool matchd my home plunge. I'd like to have a more precise or standard way of doing this in the future if/when I have to work on my machine again.
Any suggestions?
Old 03-02-2011, 05:52 PM
bumped to Wednesday.
thanks!
Old 03-03-2011, 06:58 AM
Bwana Don's Avatar
Bwana Don is on a distinguished road
Put a precision hole in the fixture. This becomes your datum. Swing the hole to set or verify position. Everything comes off the datum for machining. We also set "Z" datum to table top on the machines.
If you ever move the fixture off the table just swing the hole when setting up and set datums from it.
Hope this helps.
Still working in the "D".
Need Help!- My Machine's Home just changed by .070 and fixture plates won't work I'm in trouble!! 777funk BobCad-Cam 14 02-24-2011 07:27 AM
Home Switches - Best Location??? CanAm1 Mach Software (ArtSoft software) 3 12-14-2010 05:33 PM
Need Help!- BP Interact 1 Mark 2 hancockj Bridgeport and Hardinge Mills 2 03-12-2009 07:26 AM
Hurco 425 Mark 2 EDM haslagl HURCO 0 07-03-2007 12:28 PM
Micro Mark xa_shall Mini Lathe 12 11-10-2005 04:24 PM
