Results 1 to 3 of 3
Thread: insert for a 0.005 max inside radius
    Apr 2010
    I need to cut a 0.005 max inside radius on a corner on a lathe. Can anyone recommend a tool/insert for doing this.
    www.machmachine.com
    Registered Shane123's Avatar
    Jul 2010
    Quote Originally Posted by dingo0722 View Post
    if its OD, you can use your parting tool, and grind the insert to your liking if you dont have one without a radius. if its ID, same process but with a ID grooving bar. just use that tool for radius cleanup only, whether it is the OD or ID.
    Jan 2007
    cermet .004 rad insert ccmt then take a hone and file it slightly giving you a .002-.003 then interpolate a rad of .004.
    if you plunge it 99% of the time you will get a ****ty part and be out of spec. Leaving an undercut.
    even if you take that .004 rad insert and interpolate a .0045 it will be better than plunging.
    Delw
  1. Need Help!- Radius to end of Arc Differs From Radius to Startline
    By Bob La Londe in forum Machines running Mach Software
    Last Post: 08-09-2010, 10:16 PM
  2. Replies: 8
    Last Post: 11-15-2009, 07:35 AM
  3. Need Help!- Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 12:28 AM
  4. Radius breaking off threading insert!
    By northernmach in forum General Metal Working Machines
    Last Post: 12-12-2006, 10:27 AM
  5. What's inside this box?
    By Bloy2004 in forum General Electronics Discussion
    Last Post: 04-07-2004, 10:07 PM
