Need some help from you guys if possible. I need to machine a 0.6mm wide slot, 1mm deep in SKD11 (D2). I can't find any data for anything this small. I'm planning on using a 0.5mm 2F TiALN endmill to rough it, and maybe a 0.6mm 2F TiALN endmill to finish it to size (one pass). In my book for these cutters it only goes down to 1mm and shows 34,200rpm & 150mm/min. which would be Vc 107 & F/tooth 0.0022mm. Recommendation for slotting is Ad=0.15D, so for the above 1mm cutter 0.15mm Would I be right in starting at 10,000rpm with my 0.5mm endmill, as that's all my Haas VF2 has, then 0.001mm/tooth and a 0.075 step down? Any help much appreciated |
| Milling SKD11 steel | mattpatt | General Metalwork Discussion | 2 | 06-05-2009 02:44 AM |
| cutting a slot with a t-slot cutter | cncuser1 | Mastercam | 11 | 09-09-2008 09:02 PM |
| Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill? | weaston | General Metalwork Discussion | 7 | 04-11-2007 09:00 PM |
| T-Slot | dafowfidy | Syil Products | 2 | 02-24-2007 02:28 AM |
