#14
| Well keying off of DLMACHINE's observation of what is occuring at auctions..."manual machines selling for a premium over CNC" because of us.....leads me to recommend that if you can undertake a CNC retrofit of a CNC machine...that may be the way to go. |
#15
However on the other hand if things take off don't forget the importance of that college education.
miljnor and DL... both have hit things on the head. It may be far easier to get into some basic CNC hardware due to current market conditions. As long as you have a manual capacity in some form it is the way to go. As to lathe or mill as the first CNC device well that sort of depends on what you expect to do. I know of one guy that ran a bunch of lathes in his basment making very small parts for years. It is a matter of the type of work you intend to pursue, when I here job shop though I think CNC mill. Thanks Dave |
#16
| The idea of working your way though college with your own business is not unheard of. It won't be easy either. Many business will have trouble dealing with part time business but there won't be enough of these to matter to much. You might find that there will be potential business available to you simply because you are working your way through college. Frankly the best reason to go the CNC route is that the machine itself can work for you while you are studying. Or more likely sleeping. One word of caution though with respect to used CNC equipment. If you are not inclined to make repairs or upgrades your self you may need to rethink used CNC. The bargains are there because no body wants the headaches that go with fixing old hardware. A person with the right aptitiude might not have much of an issue with this though. dave
#18
#19
#20
| Going for the Super Mini Mill has advantages over the VF1 that could apply in your planning. The machine weighs in at about 4500 to 5000 lbs with the extra Z clearance compared with 8000lb for the VF1 and it occupies less space. The SMM does not need to be accurately levelled because it is a small machine and sits on a rigid steel fabrication that is also the coolant tank. If you are setting up a small shop and may be in the position of sharing space or get into some place with limited access to save money the SMM is much easier to move. Also it comes with a 10000 rpm spindle and 1200 ipm rapids compared with 7500 and 750 on the VF1 (unless it has been upgraded). |
#21
| MBG You could try starting here http://www.machinetools.com/MT/Machi...MachineID=2740. I also suggest looking at Fadal for economical yet good machine options.
