while trying to quickly whip a new assembly together I had an aluminum part that was 4x4x.5 thick , so i threw it into the vise with stepped soft jaws and in the end end result there was to be a vise hold of about .075 , which I new was going to be somewhat flimsy , so anyhow while standing at the machine with my hand wrapped around the door handle , I leaned up against the door while watching the part and the controller , the sob part launched and labeled the door and my arm , lucky enough the lexan hasn't become brittle yet or I would have been pulling plastic and a 4 inch chunk of aluminum out of my arm . I've launched enough parts in my time but this one flew harder and faster than any of them crappy pictures but it gets the point across , no blood or gore but its tender live an learn
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| I knew I was treading on thin ice so at 10k i figured that running it at 50 ipm would have been slow enough for full engagement at a bit more than a 1/4" depth but sometimes i forget how aggressive the hi helix can be( i love em ) , I lightened the depth and ran another one , without leaning up against the door which is going to be a very difficult habit to break
| LOL yeh but I'm a bit thick sometimes , like the lab rat that gets zapped every time he bites the cheese
| We sent an aluminum bar through the side of the machining center. It went right through the sheet metal. Just underneath the controller. RPM was 15,000 feed was probably arpund 200 ipm. Operator forgot to tighten the vise up! Lucky no one was hurt.
__________________ Still working in the "D". |
#10
| How about some high speed balancing launches? I know of one flywheel explosion that exited through the roof and landed on I-94. Also, a taper cone pulley went through the shielded roof of the balance area, ricocheted of the overhead crane and landed in the chip pan of a W&S 5A turret lathe. In both cases no injuries except to underwear.LOL Dick Z
__________________ DZASTR |
#11
| Man your lucky! We had a guy at work lean in to a hurco door the other day while the machine was running. Dam cheap machines, window fell right in and so did he. Just got wet thank god. I've seen double walled doors blown off lathes from part ejections, ceiling joists taken out, guys in comas, holes through castings, cross slides on big lathes ripped completely off, holders actually imbeded in the safety windows. Good reason to change the safety windows every five years as suggested by most manufactures. |
#12
| most machines that I've worked on in the past have had metal reinforcements around the windows which i think is the safest , that way nothing "should" fly out of the machine , I recall running parts in the past that were high precision and we could barely clamp down on them for the reaming (final) op , otherwise things would get whacked out , I had a 3/4" reamer pull the 50lb+ part to z zero (eye level) at about 750 rpm , by the time i hit estop and took a flying leap from the steps the part was thrown to the back of the machine , the flash picture that flashed thru my mind was the thing flying thru the unprotected glass
| Production Work Needed - EDM, Milling, Grinding *door to door free shipping* | FreedomTechUsa | Product Announcements & Manufacturer News | 0 | 03-11-2010 10:30 AM |
| For some reason G20 is Centimetres | VanCnc | Fanuc | 9 | 04-09-2009 09:12 PM |
| Loosing Steps, Machine Stall, for no Apparent Reason | JoeDawg | Benchtop Machines | 5 | 12-19-2008 06:47 AM |
| I want one and now I have a reason. | rustranch | DIY-CNC Router Table Machines | 2 | 10-09-2003 10:58 PM |
| CNC for what reason? | WallCrawler | CNCzone Club House | 6 | 06-17-2003 11:30 AM |
