Old 02-21-2011, 05:09 PM
twocik is on a distinguished road
9 x 20 Lathe Gears Broken... Where to buy new ?
Today I had two gear break on me and wanted to know if anyone here could recommend where to get new ones from....
It's a Harbor Freight 9 x 20 lathe, about 4 years old and no warranty left. I'm hoping I can buy better gears than what came with, as well as keeping the same pitch (?) so that all feeds are still correct....
Here are a some pics to show what's going on
Last is this gear rack and which I believe is a worm gear needed if I want to convert this to cnc ?
Old 02-21-2011, 10:36 PM
doorknob's Avatar
doorknob is on a distinguished road
By any chance is that the same machine (with a different paint job) as a Grizzly G4000? They call it a 9 x 19, but it may possibly be the same as the 9 x 20.
If so, Grizzly has a parts list on their site as well as a parts order form.
See the following for more info:
G4000 9" x 19" Bench Lathe
http://cdn5.grizzly.com/partslists/g4000_pl.pdf
http://www.grizzly.com/products/g4000/parts
Old 02-21-2011, 10:50 PM
I hope so because finding them thru Harbor Freight is a joke. I guess this is why the Grizzly cost more.....
Can anyone confirm this ?
Old 02-22-2011, 02:50 AM
DEMAC is on a distinguished road
contact little machine shop !
regards
Old 02-23-2011, 10:22 AM
neutronics is on a distinguished road
Can't go wrong with Little Machine Shop! I've been to their shop - very professional outfit and they'll do you right (IF they have your parts).
LittleMachineShop.com - Replacement Parts
Grizzly is also an option, but if I were in that position I'd give LMS a call first.
Old 02-27-2011, 08:00 AM
handlewanker is on a distinguished road
I cut gears for my screw cutting train using a Nylon material...about 10 years ago now, and they're still going OK.
Ian.
Trying to find change gears for Emco Compact 10 lathe DZW General Metal Working Machines 2 02-16-2010 06:04 AM
Newbie- Mini Lathe (7Xx) metal gears lubrication wildwestpat Mini Lathe 0 05-13-2009 03:18 PM
Hardinge HLV-H Lathe, change gears, 127 tooth leeputman General Metal Working Machines 6 01-18-2008 07:29 AM
How to Switch Gears on a Lathe Crashmaster General Metal Working Machines 2 06-26-2007 07:06 AM
