Old 02-18-2011, 12:46 PM
R5P7Duster is on a distinguished road
Triangulation Help Please.. Pic enclosed
I'm trying to figure out how to figure out what dimension the triangles need to be for my project. The base of them is 5" they are 7" long and the are meeting up with a 3" OD tube. Thanks for any help
Old 02-18-2011, 12:48 PM
Also I'm not very concerned with the fitment of the 3" tube as it will be welded and small gaps can be filled.
Old 02-18-2011, 04:40 PM
Kiwi is on a distinguished road
Is this what you need?
Name:	R5P7 Duster.JPG‎
Old 02-18-2011, 06:24 PM
holbieone's Avatar
holbieone is on a distinguished road
give this a try
Old 02-18-2011, 10:02 PM
neilw20's Avatar
neilw20 is on a distinguished road
How do you guys measure those angle so accurately?
With all that accuracy, how are the two presentations differing by quite a bit in one of the dimensions.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 02-18-2011, 11:24 PM
Originally Posted by neilw20 View Post
... how are the two presentations differing by quite a bit in one of the dimensions.
The specs don't list the number of 'triangles'. Looking at the picture, I believe there are three around 90 deg. (eight around 360deg.)
Name:	R5P7 Duster4.JPG‎
Old 02-18-2011, 11:50 PM
holbieone's Avatar
i drew a triangle based on 5.00" on the base and 7.00" long plus the 1.5" radius of the tube
that gets you the middle section ,but more info. is needed for both end sections
Old 02-19-2011, 12:26 AM
Originally Posted by holbieone View Post
....i drew a triangle based on 5.00" on the base and 7.00" long plus the 1.5" radius of the tube....
What does the 0.8824" relate to?
Old 02-21-2011, 02:00 PM
Thanks for the posts. I was hoping to get an equation. When I try to mate the edges in solidworks they won't mate cause the angles are off by 1-2*.
Old 02-21-2011, 03:26 PM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
The inverses of the trigonometric ratios are denoted in the three different ways, which are shown below.
x = sin y
y = sin-1 x
y = arcsin x
Arcsin x is a number whose sine is x.
Some rotations do not have values for the inverse trig. functions. 100o is an example that does not have an arcsin. The ranges of the inverse functions are listed below.
y = Arcsin x [-((PI)/2), (PI)/2]
y = Arccos x [0, (PI)]
y = Arctan x [-((PI)/2), (PI)/2]
Example:
1. Problem: Find Arcsin ((SQRT(2))/2).
Solution: Using a unit circle like the
one pictured below, you
can see that there is only one
angle in the Arcsin's
range that has a sine of
(SQRT(2))/2. That
angle is (PI)/4.
  #11   Ban this user!
Old 02-21-2011, 03:30 PM
Angles are also called rotations because they can be formed by rotating a ray around the origin on the coordinate plane. The initial side is the x-axis and the ray that has been rotated to form an angle is the terminal side.
Reference angles are useful when dealing with rotations that end in the second, third, or fourth quadrants. A reference angle for a rotation is the acute angle formed by the terminal side and the x-axis. Example:
1. Problem: Find the reference angle
for theta
Solution: To find the measure of the
subtract the measure of theta from
180o.
180 - 115 = 65
The reference angle is 65o.
Once you have found the reference angle, use it to determine the trig. function values. Consider, for example, an angle of 150o. The terminal side makes a 30o angle with the x-axis, since 180 - 150 = 30. As the figure below shows, triangle ONR is congruent to triangle ON'R'; therefore, the ratios of the sides of the two triangles are the same, although the ratios may have different signs. (You could determine the function values directly from triangle ONR, but that is not necessary if you remember that the sine is positive and the cosine and tangent are negative in quadrant II.)
http://www.mathwarehouse.com/transfo...ns-in-math.php
ID:	127062   Click image for larger version
ID:	127063   Click image for larger version
  #12   Ban this user!
Old 02-21-2011, 06:35 PM
Perfect Circle's formula is over my head.
This is how I would work out the angles:
Deg. the 'triangle' section on the 3'' tube = 45deg.
Tan(45/2) * (3/2) = 0.62132 ________________(3 = tube dia.)
(5/2) - 0.62132 = 1.87868 ________________(5 = 'triangle' side)
ATan(1.87868/7) = 15.023 deg + 90 = 105.023deg ____________(7 = 'triangle' length)
180deg - 105.023 = 74.977 deg.
Answer = 105.023 and 74.977 deg. when the 'triangle' end length is 45deg of the 3" tube.
Need Help!- volume enclosed into part rpais85 Solidworks 1 02-18-2011 03:14 PM
Semi enclosed NM 200 Setup g29cc Novakon Systems 6 08-17-2010 03:42 PM
Harbor Freight X2 Mini Mill Fully Enclosed Adamj12b Benchtop Machines 13 01-30-2010 01:40 AM
Newbie- Will be grateful for your insight on the enclosed CNC router Ariel6789 Wood Lathes / Mills 0 10-09-2009 02:27 AM
Enclosed Blowers Wendekreis Laser Engraving & Cutting Machines 8 08-08-2008 09:20 AM
