Old 08-01-2005, 06:15 PM
Gold Member
lerman is on a distinguished road
How Can I Deburr A Manifold?
I'm machining a manifold from 6061 aluminum. The manifold is part of an instrument and has many intersecting passages, some of them threaded.
They range in diameter from 7/64 to 7/16 inch. I have 5/16 holes intersecting the bottom of the 7/64 holes. I have perpendicular #17 holes where the bottoms meet at a right angle.
For the most part, I'm using roll form taps, but have been unable to find 7/16-20 roll form taps.
Any ideas would be appreciated.
Thanks,
Ken
Any suggestions on how to minimize the burrs and deburr these things?
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Last edited by lerman; 08-01-2005 at 06:18 PM. Reason: I'm a software guy and wrote debug instead of deburr.
Old 08-01-2005, 08:51 PM
Gold Member
Ken_Shea is on a distinguished road
Ken, you can get the 7/16-20 here
http://www1.mscdirect.com/CGI/N2DRVSH
Are you saying that the Form Tap is burred, I thought smoother threading was one of the benefits of form taps?
Is the 6061 soft or tempered like T6 for example ? I have found that softer aluminum has more burring problems then the harder tempered materials.
Would cleaning brushes for pistols work, they come in many sizes and materials, SS, nylon, bronze etc.
The other Ken
Old 08-01-2005, 08:54 PM
mark c's Avatar
mark c is on a distinguished road
Talking
Try this link:
http://www1.mscdirect.com/CGI/NNSRIT...&PMT4NO=490971
It"s for Balax taps. I've had very good luck with them
Insanity "doing the same thing and expecting a different result"
Mark
www.mcoates.com
Old 08-01-2005, 08:56 PM
Gold Member
The other Ken
No, one of the reasons I'm using the forms taps is because they don't generate burrs.
Offhand, I don't know the temper. But most of the stuff I buy is T6.
The problems are where the holes intersect, where a threaded hole crosses a hole that partially intersects another hole, etc.
Thanks for the link.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 08-02-2005, 10:35 AM
Runner4404spd is on a distinguished road
when i designed manifolds for air and hydraulic use we used a company called thermo burr. they basically put your part in a giant gas chamber and blow it up. all the burrs burn off and the manifold comes out clean.
there maybe one in your area. if you need drop me a line and i can probably get you their contact info.
