Old 07-27-2005, 12:20 PM
rrrrrgh is on a distinguished road
Thread Forming
Any advise on thread forming a 1/4-20 2b x .560 deep in brass.
Type of tap coated or uncoated.
Feed and speed.
Type of holder.
Old 07-27-2005, 03:23 PM
psychomill is on a distinguished road
What kind of brass? For the most part, 1/4-20 is not big deal on it. Brass is fairly abrasive, so if you have a 'ton' of holes to do, go coated. If not, uncoated will work fine. I usually use coated hi-spiral cut taps in it. Roll taps will work also, unless its real soft which usually causes gaulling on the tap. In this case, cut tap will work better. You can run brass like aluminum.
It's just a part..... cutter still goes round and round....
Old 07-27-2005, 04:50 PM
Gold Member
JFettig is on a distinguished road
I do a lot of smaller cold forming, did some brass, it was a little more difficult than Al and Cu, I would go coated. Just make sure you have the right size hole, its not the same as with a cutting tap.
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
