| I am going to machine splines in a shaft with gear hobbing machine. The design requires a missing spline tooth (a mating part align the missing spline tooth on shaft). How do you get the missing tooth? the area cannot be flat after the teeth is removed. Thanks |
| I know you can mill splines acurately because I believe the offroad industry does this with axle shafts (saw an artical in 4wheel mag with currie Ent doing this). But I beleive all of the manufacturers do something like this. Some probabably use a gear machine but others use the old school milling.
__________________ thanks Michael T. "If you don't stand for something, chances are, you'll fall for anything!" |
| so the spot with the missing tooth on the male piece has to be the same radius as the minor dia? yuk. if a design change is not possible, or it really can't be flat then 1) facet it either by rocking the lathe carriage or in the mill and then finish with a find file, or 2) with an slot drill smaller than 2x the width of the space between splines (at the bottom) in a vertical mill and the work held in an index head, centre the work, bring the cutter down and cut the radius by rotating the head back and forth. Technically it should be a slot drill cuz its going to be like a plunge cut as you rotate - ie the last little bit gets taken out by the centre of the cutter. (At least that’s how I remember it when I did something similar) |
