Old 07-27-2005, 03:09 AM
ACME is on a distinguished road
tool setter
hi,
where can buy tool setter for z-axis?
thanks
Old 07-27-2005, 07:36 AM
Gold Member
JFettig is on a distinguished road
deskcnc has one, thats all I can think of, you could buy a light up touchprobe from msc or somewhere else and wire it to the computer instead. Or you can try to make one which I tried once, plan to again in the future.
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
Old 07-27-2005, 12:13 PM
psychomill is on a distinguished road
What style are you looking for? Are you looking for just a mobile type for operators at the machine? Are you looking to install one on a machine? Are you looking for an external pre-setter? Optical, laser, touch or mechanical? For what machine (CNC mill, manual mill, lathes, ... )?
Theres a ton of them for different reasons, mounting and from several manufacturers.
It's just a part..... cutter still goes round and round....
Old 07-27-2005, 10:16 PM
hi,
i looking for one something like that http://www.nsknet.or.jp/nisshin/en/e-frametop.htm dont know where can buy that i-50
yes, mobile type... for my little sherline cnc mill
and looking for one safety internet shop for shopping with credit card
sorry, Jon, deskcnc one look very good but too expensive to me
thanks
Old 07-28-2005, 08:24 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
MSC direct has this sort of thing.
Regards,
Mark
www.wrathall.com
Old 07-28-2005, 10:12 AM
Nisshin has to be bought direct I believe. You can also check these from Lyndex (they have 4 different models), SPI, ( or this one ) , etc.
I've even just used something simple like a 1-2-3 block. Just as long as you standardize, it works fine.
HTH
Old 07-28-2005, 10:14 AM
Gold Member
Ken_Shea is on a distinguished road
ACME,
Electronic unit at enco:
http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=951637
Ken
There is an affordable mechanical unit also but could not find it.
Personally I like dials
Here it the mechanical,
Bulkier then the one I use and not the precision but is also $250 less money and should be fine within +/- .001 or so, which ain't shabby tolerances.
Unlike th electronic versions mechanical works on all material, not just conductive.
http://cgi.ebay.com/PRECISION-Z-AXIS...QQcmdZViewItem
Old 07-30-2005, 12:00 PM
thanks, i got it...
Old 07-30-2005, 12:15 PM
Gold Member
Which type did you decide on ?
