Old 01-29-2011, 10:20 AM
crowconor is on a distinguished road
Ti Milling
Hey I'm from a High School Robotics team. We make 15lb robots to fight. We are trying to mill Titanium for a part we need. I have read the HSS bits can be better to use for milling Ti, is this true? Also what would should we use for speeds and feeds? We have a tormach PCNC 1100, we are pretty comfortable milling aluminum and mild steel. Any help at all would be awesome.
Here is our youtube channel, check it out! YouTube - hhsrobotics's Channel
Thanks!
Old 01-29-2011, 04:29 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Look up "STARCUT" rippers by Hanita. Have found those to be pretty useful milling Pegasus engine compressor discs....
DP
Old 02-02-2011, 09:32 AM
thanks, any help on speeds and feeds?
Old 02-02-2011, 02:23 PM
Fadal Error is on a distinguished road
I use SGS Z-Carb end mills when I mill titanium. You can usually call the cutter manufacturer and get their recommended speeds and feeds.
Old 02-02-2011, 02:42 PM
Bwana Don's Avatar
Bwana Don is on a distinguished road
Carbide all the way, use coolant too. A good coating will help, such as TiCN or TiAlN. Most of the main tool manufactureres will have carbide end mills made for Titanium.
Don't *****foot around, slower speeds and a decent chipload. No dwelling at all, this stuff workhardens like nothing else. Drilling we use coolant fed drills. I like Guhring (drills/mills) or Helical Solutions (end mills).
Follow manufacturer recomendations for speeds and feeds. In a pinch I use 180 sfpm for mills and .001 -.003 ipt for mills. It depends on the size, check the recomendations first.
I cut titanium all day long and it isn't that hard. Easier than some of the stainless we have to cut. Sharp cutters and no dwelling.
Still working in the "D".
Retrofit my Old Milling (Milling No. 0) mistry_hemant General CNC (Mill and Lathe) Control Software (NC) 0 01-17-2011 04:08 AM
CNC Milling Machine Packages and Bespoke CNC Milling Machines worldofcnc Product Announcements & Manufacturer News 0 05-27-2010 08:20 AM
PCB milling Ubarch Benchtop Machines 6 03-27-2009 12:56 PM
Offset Chain Milling vs Path Milling ynnek TurboCAD/CAM 1 03-11-2009 05:29 PM
Milling with bottom vs milling with side? REVCAM_Bob CNCzone Club House 13 06-30-2008 09:23 AM
