Thought I would ask here for ideas, I'm looking for a way to convert rotary motion into about 12-13" of reciprocating travel, with a fairly heavy load- 200-250lbs? in one direction only. In the past I used a rather large pulley setup to accomplish this, but Im wanting to redesign things into a small size and do away with large and costly pulleys. I've been thinking about it for awhile now but cant seem to come up with a design that would work. I know this isnt alot of info to go on, but if anyone has any suggestions I'd love to hear them. Thanks Ben W
__________________ www.custommetalworking.com |
| If you do consider pneumatic and want to deliver stroke-to-stroke consistent speed timing and positioning, then I would look at using an air over oil pneumatic system. This has the advantage of a hydraulic system with lower cost and less noise than all hydraulic. If this is just simple point to point positioning, then travel limit switches should be quite accurate. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 01-26-2011 at 11:07 AM. |
| Well It needs to be powered by 120v AC so it can be used in a variety of places. I was pretty sure there was a way to pull this off without using large pulleys, but I havent been able to come up with anything yet.
| Then a linear actuator is probably the answer, these are self contained units with a motor and gear box on one end, probably as portable as you are going to get. Search ebay with Linear Actuator for an idea. They also come with settable limits. A heavier duty option is Nook Ballscrew Jacks. http://www.nookindustries.com/Jack/JackInch.cfm Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 01-26-2011 at 01:52 PM. |
| linear to rotary | LarryP | Linear and Rotary Motion | 3 | 12-31-2010 05:51 PM |
| Parker Linear Motor - IKO 35 series 69" linear Rails | S.A.C. | EBAY ADS | 1 | 07-28-2010 08:33 AM |
| Accurate rotary to linear translation | vger | Linear and Rotary Motion | 2 | 05-17-2009 10:29 AM |
| Interesting rotary to linear action | BillTodd | Linear and Rotary Motion | 0 | 01-19-2009 11:54 AM |
| Rotary to linear torque converter. | flakker | Mechanical Calculations/Engineering Design | 0 | 03-21-2007 07:55 AM |
