I have a question about how best to use a CNC mill for "surface grinding" forged damascus billets of steel coated in flux and scale. I recently began forging damascus billets. These billets come out of the forge with flux and scale on them which needs to be removed. Next I need to finish the billet flat so I can effectively use me CNC machine to work the metal. Rather than buying a dedicated surface grinder I would like to use a face mill or fly cuter perhaps to go through this process. My concern is that these billets are coverd in flux (melted glass essentially) and I am not sure what is the best tool to use to get me where I want to go. What is a safe and cost effective tool to use for this? Any insights would be appreciated. Shane Harvey |
| What are you making, sword blanks? ![]() It is possible that machining is not the best approach. First the scale and flux is murder on cutting tools. To try and get acceptable tool life you need to run at a modest speed with a good depth of cut and a good feed to get below all the horrible stuff and peel chips off in clean metal. Which leads to the 'second'; because you are attacking a rough surface with and aggressive cut and feed you get a lot of impact on the part and with it being a rough forging you might have difficulty holding it firm enough. Grinding is a much lower impact method of removing a bad surface. Have you tried getting these forgings roughed to smooth surfaces in a local machine shop. If you find someone to do it and the cost is acceptable then it may be easier than I anticipate and you may be able to do it cost effectively yourself. If you cannot find someone willing to do it on a CNC machine that could be a hint that it is a horrible job to do in which case you might want to reconsider a grinder.
| Geof, Yup, essentially I am making sword and knife blanks. Thanks for you thoughts. I have considered using cheap fly cutters, cut kinda deep as you suggested to get the real terrible stuff off, and then perhaps using a face mill for a finishing pass. I am taking you suggesting to try a local machine shop and calling around. Thanks again. Shane |
This video shows using a CNC machine to surface grind. Does anybody know where to buy the tool doing the surfacing? YouTube - SX3 CNC Surface Grinding 2Shane |
| The simplest and cheapest thing to do is to have these blanks ground on a Blanchard. Ie: a rotary surface grinder. it holds with a mag and grinds under flood coolant. A blanchard is the IDEAL tool for this task. Call your local grinding shops and ask if they do blanchard grinding or rotary surface grinding.
__________________ Nate. Ann Arbor Meechigan |
| Newbie- ISO Surface Grinding Primer | r11449 | General Metalwork Discussion | 2 | 03-21-2009 12:04 PM |
| Surface Grinding | neilw20 | Syil Products | 5 | 08-12-2008 01:27 AM |
| Why is surface grinding so accurate... | WilliamD | General Metal Working Machines | 11 | 07-22-2007 06:14 AM |
| Surface Grinding Woes | Zumba | General Metalwork Discussion | 25 | 03-20-2007 10:37 PM |
| Surface Grinding Aluminum? | kumaichi | General Metalwork Discussion | 8 | 10-31-2006 06:24 AM |
