Old 01-24-2011, 08:00 PM
mutski is on a distinguished road
Correct bits for making holes in aluminium
Hi all
I'm sorry, I'm sure you answer this question a lot but the search tool just finds soooo much not really relating to my question.
I'm new to CNC routing. I've just got a small 600x400 desktop router. We want to be able to make cutouts in up to 3mm aluminium to mount various switches, buttons, LCD displays etc. I'm really not too sure what kind of bit to use though. I thought carbide was the way to go, so I got some Dremel 9904 bits (tungsten carbide). They seem to work, but the flutes fill up very quickly which means they dont cut very well and I have to stop the machine and clean them out (which is hard).
I'm running the feedrate at 500mm/min, 0.2mm/pass which seems to be what people are suggesting reading the forums here.
What kind of bits should I be looking for?
Cheers - Matt
Old 01-24-2011, 08:23 PM
-Chris- is on a distinguished road
tools for al
Hi not sure abouy the bit your useing by your discreption but it sounds like your not useing any coolant. it doesent take long before aluminum starts smearing and loading a tool without something to lube things up, spray a little wd or trans fluid on cutter and sheet while cutting. they do make mist systems to keep the cutter cool and lubricated kool mist is one
Old 01-24-2011, 08:40 PM
I have been spraying a lubricant which is similar to WD-40 that claims to be good for cutting. This morning I got a dedicated cutting liquid from Sutton. Maybe I'm not using enough. I'll try using a bit more as it cuts.
Cheers for replying - Matt
Old 01-24-2011, 09:18 PM
I just tried a 8mm diameter hole in 2.5mm thick aluminium with HEAPS of cutting fluid. Didn't seem to make any difference to the amount of aly that's now stuck in the flutes. The Dremel 9904 has about 8 flutes in a 2.4mm bit. I think the flutes are too small for this application.
Matt
Old 01-24-2011, 09:24 PM
keebler303 is on a distinguished road
1) Dremel bits are of poor quality to start with. I wouldn't recommend them.
2) It sounds like you are using a burr, not an endmill. It will never work.
3) Buy a good quality 2 or 3 flute carbide endmill and you will never look back.
Possible sources include enco, mcmaster carr, msc, etc.
Good Luck
Matt
hpowell is on a distinguished road
You have too many flutes. As well as floog or mist coolant, aluminum needs as much room as possible to evacuate. I suggest no more than three flutes.
Harry
Harry
Old 01-24-2011, 09:25 PM
That should be "flood or mist"
Harry
Old 01-24-2011, 10:13 PM
Thanks for the help everyone. Now that I know what to look for it makes it easier going through catalogues.
I'm going to order some of these:
Solid Carbide End Mills 2 Flute
Is that what I'm after?
Cheer - Matt
Old 01-24-2011, 10:50 PM
Yep. Get high-helix, sometimes called "Streaker".
Harry
Old 01-25-2011, 08:07 AM
WidgetWorks_Unlimited is on a distinguished road
The proper tool depends a lot on your spindle capabilities.
If you're using a wood router that runs at 20,000 RPM then switching to standard end mills meant for metal cutting won't help - most metal cutting is done at much lower RPM.
For the wood routers you'll need a single flute "O-flute" cutter. The flute is polished to reduce chip buildup and the rake and helix angle are specifically designed for aluminum chip evacuation. Buy a tool with the shortest depth of cut that will handle the thickness of your material.
Onsrud makes an .125" cutter .250 DOC for about $30 ea - you can cut aluminum at 20,000 RPM without any coolant.
Also, you need the right alloy of aluminum to cut without flood coolant - 6061 is the most common and works great.
Finally, you need to move the cutter fast enough to make chips. Going too slow will cause major problems.
  #11   Ban this user!
Old 01-25-2011, 11:47 AM
CNCMAN172 is on a distinguished road
Cutting Aluminum
As other have said you really need to understand a few aspects of your machine to successfully cut aluminum.
Spindle Speed is critical
Depth of Cut also varies greatly depending on your spindle power
Cutters need to be very sharp and I recommend 2 Flute cutters, however some 3 Flute cutters are design for aluminum.
When your cutters are gumming up this can be caused by several factors. The wrong cutter, too many flutes on the cutter, lack of cutting fluid, depth of cut too deep, feedrate too fast, etc.
There are some very nice Onsrud single flute cutters that can cut that tin aluminum 3mm in a single pass depending on your spindle power like a previous poster mentioned.
I have been very successful using 1/8" carbide 2 flute endmills on my little home built mill. I have to turn my Bosch router down to about 12,000 rpm and set my depth of cut to .025" and my feedrate to 8 ipm. I also recommend a small amount of WD40 and start off with a feedrate of 4 ipm and then start increasing and listening to your machine.
The type of alumium is just as important as all these other elements. Some aluminum just machines terrible. you can go online and review the various types of aluminum and they describe the best types for machining. As another user posted 6061 is very popular and machines very nicely.
Hope this helps. Good Luck
CNCMAN172
  #12   Ban this user!
Old 01-25-2011, 07:12 PM
macdarren is on a distinguished road
not an expert by any stretch of the word but 500mm/min seems fast to me unless this is a higher end cnc with the proper tooling and cooling.
Tags
aluminium, carbide cutter
Huge Newb questoins. Need help making a few holes hudd General Metal Working Machines 0 03-06-2010 09:37 PM
What is the best method for boring large holes in aluminium bar? Blakelidge Taig Mills & Lathes 14 06-15-2009 10:44 AM
Making holes coolman General Metalwork Discussion 4 04-27-2006 07:16 AM
bits for drilling holes posix WoodWorking 4 03-09-2006 11:41 AM
Router bits. ( Aluminium veneer ) ynneb DIY-CNC Router Table Machines 17 05-12-2004 10:49 AM
