Old 01-21-2011, 03:12 PM
ARIK is on a distinguished road
Smile Special thin washers cutting on CNC lathe
We are running thin washers job: OD=0.25" ID=0.1" and the thickness is 0.015" only. The washers are from AL 6061-T6
Any tips and tricks regarding how to minimize the burrs left after cutting and improving surface finish?
Arik at Micron E.M.E Ltd.
Old 01-21-2011, 05:38 PM
Shane123's Avatar
Shane123 is on a distinguished road
change your g97 to g96 for constant surface feed with your cutter. I like to run mine at g96 s450 with the max spindle at about 1200 for cutoff, and feed about .002 per rev, sometimes .001 depending on the finish... that will give you a better finish. as for burrs, i am assuming you are talking about the burr on the hole on the cutoff side? If you are, you can get cutoff inserts (or grind your cutoff) to be angled toward the part side. it helps but is not always the cure. you might need to to use some needle nose to pull the burr and then rub the cut off side on a sheet of emory paper.
Old 01-21-2011, 09:40 PM
Sinistersam is on a distinguished road
I don't really have any experience with something like that, but the first thought in my mind was the use of a vibratory tumbler. It should deburr and put a finish on them, in mass quantity.
Old 01-22-2011, 04:23 AM
Monkey King's Avatar
Monkey King is on a distinguished road
If you do in mass, better by blanking die.
Old 01-22-2011, 04:59 AM
Thanks shane and Monkey king.
I will try the G96 and update you, I can not make it using die since those are special washers with 3D face surface, they must be machined.
Arik
Old 01-27-2011, 12:08 PM
mattstawicki is on a distinguished road
Arik
If you want to cut them off clean, grind your cut-off tool 20 degrees across the front (point towards the part), w/ 18 degrees clearance (under). 3-4 degrees clearance (under) on each side, and tapered back 1-2 degrees on each side. I'd run it at least 6000 rpm's, with a .0005-.0007 feed. Also, keep the tool as narrow as possible to reduce cutting pressure and the size of the chip that will rub on the part. If I was using 1/4" barstock, I'd make the tool around .035 wide.
Tags
lathe, miniature parts
Need Help!- cutting a large thin ring mikede General Metalwork Discussion 2 11-23-2010 01:55 PM
What to use when cutting thin materials ? twocik Benchtop Machines 5 04-07-2008 03:49 PM
cutting thin metal clittle Opensource Forum Rules 3 09-05-2007 04:27 PM
Cutting thin aluminum neonguy CNC Plasma and Waterjet Machines 2 10-13-2006 08:29 AM
Cutting Thin Wall Tubings creative_mind General Metalwork Discussion 4 08-15-2004 02:19 AM
