Hey all, I have my 10" Delta drill press and a decent set of HSS bits that go up to 1/4". However, now I need to drill some 1" and 2" size holes in some 1/4" 6061 plate. I bought a set of Harbor Freight el-cheapo-chinese forstner bits for a project (the Underwater ROV). They worked great for the plastic I was milling, but they have a million warning not to use them on metal. So, how does one go about making larger round holes in Alum. when they only have a drill press?
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452 |
| In 1/4" you might be able to get away with buying whats called a "S&D" drill (Silver and Deming). For a 1", it should fit your chuck. You don't have a lot of power so just take it easy on it. I've drilled 1" + sized holes on a cheaper and smaller drill press and got by with it. The 2" hole is tough for trying to drill though. Instead, I use a hole saw. You're only going through 1/4 plate so it should be no problem. Just peck at it with some cutting fluid brushed on.
__________________ It's just a part..... cutter still goes round and round.... |
Holes saws tend to make really sloppy holes though - but that why there is sandpaper! I know I have a decent set in that size...
Seriously though, what is a boring head? I've seen them in catalogs, but I don't know how they work...
| Drill the holes in MDF with the forstner bits. Use a hole saw about 1/8" smaller than the finished hole size to rough out the hole. Clamp the mdf into position and use a router (slowly) with a pattern bit to clean up the hole. It's a bit hard to see, but that's how I did the holes in these plates. http://www.cnczone.com/forums/attach...tachmentid=644
| I know this sounds stupid but it works really well. Spade bits (yes the cheap ones) work very well . I didn't believe it either but was amazed at how well they work , I've drilled a 50mm hole through 5/8 6061 Aluminum And it looks great (although I didn't mic it) it was a 2" spade bit that I ground down in a drill press to get it down to 50mm. |
| Maybe Im a little new aged but my suggestion would be to bring it to a shop that has bigger machines and ask them to drill out the hole for you? Would probably cost you less then what it would for a new tool and save you the headache. |
| Do they have to be spot on 1" & 2"? Because if you know an industrial electrician, ask him if you can use his greenlee slug-buster, this is a panel punch for conduit holes in electrical panels, this makes a quick clean hole, although you can get 1" & 2" exactly, most electricians have the conduit sizes which are slightly under and slightly over those dimensions. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#10
| how about an adjustable hole cutter it uses a hss bit and a 1/4 bit for a pilot , have used in the past and it worked well just a thought
__________________ IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#12
| I have used a spade bit as well, drilling up to 1 1/4" diameter, for making my bearing mounting blocks. I had to take it slow and just kept spraying it with WD40 (didn't have an real cutting oil) as I am using a cheapie drill press but it got the job done and it turned out surprisingly well. I have also used a 30mm forstner bit but that is really had on my drill press, the pulley belts were smoking by the time I got done. Thank goodness I only have one more of those to drill. |
