  #13   Ban this user!
Old 09-05-2005, 01:53 PM
dfranks is on a distinguished road
Just finished drilling my 2nd 30mm hole with a forstner bit & thought I would share a pic. Aluminum 6061, 30mm dia. & 3/8" deep. I took it a little slower this time. It took me about 30 minutes to finish it but no smoking belts on the drill press this time So for those of us who are not a machinist, working with a minimal of tools, there is hope. Well, I guess we'll see if it actually works when I finish this thing.
  #14   Ban this user!
Old 09-05-2005, 10:04 PM
ViperTX is on a distinguished road
It would probably help to have some of those Forstner bits that are carbide tipped.
  #15   Ban this user!
Old 09-06-2005, 08:14 AM
JavaDog's Avatar
JavaDog is on a distinguished road
Originally Posted by MILLMANM
how about an adjustable hole cutter it uses a hss bit and a 1/4 bit for a pilot , have used in the past and it worked well just a thought
Originally Posted by ViperTX
MILMANM's suggestion is to use a flycutter....they are kinda hard to find these days, but you can find them. If you were so inclined you could make your own.
You guys mean something like one of these?
FWIW, the Silver and Deming set I got from Harbor Freight = Total Crap. They are the crappiest bunch of crap bits I have ever seen. Not even close to balanced, chatter like you wouldn't beleive. I tried drilling a hole with one through some spare MDF I had laying around - I thought it was going to rip the chuck off of my press. It was so bad I got about an 1/8" into the wood before I had to stop. So, I seriously doubt these would work for the aluminum that I have.
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
  #16   Ban this user!
Old 09-06-2005, 09:54 AM
JavaDog....that is one ugly flycutter....but, yes that's the basic idea. I think the shield on the flycutter is kinda cute...
Old 09-07-2005, 10:34 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Have you looked into using a UniBit? I have used Unibits to punch 7/8" holes in thick plate before I got my mill and I seem to recall seeing a large (possibly 1" - 1.5") diameter step bit at HD or Lowes - it may have been at Fastenall...?
I think using a step drill would work well but driving power maybe an issue with a smaller drill press. If you were successful in getting the 1" hole in your plate, then you could bore it from there as previously suggested with an adjustable boring head.
Scott
Consistency is a good thing....unless you're consistently an idiot.
  #18   Ban this user!
Old 09-08-2005, 12:41 AM
beausdn is on a distinguished road
$3
Try a NEW spade bit, spend the $3, you will be surprised!
  #19   Ban this user!
Old 09-08-2005, 06:13 AM
Mcgyver is on a distinguished road
Originally Posted by JavaDog
I've seen the Silver and Deming sets...what exactly are they that differs from normal drill bits?
reduced dia shank. came up on another board recently and someone posted this link, everything and more than you ever wanted to know.
http://www.owwm.com/MfgIndex/detail.asp?ID=1017
I don't know why the drill didnt' work for you, obviously there are lots of reasons why a drill doesn't work properly, but nothing specific to the SD style except maybe its taking a bigger cut and you need to run slower with the bigger dia cutter, stil those are basic to cutting and not SD specific. machine not rigid enough? weak set up? to big a cut? dill not sharpened properly? running to quickly. all these can produce chatter when drilling
  #20   Ban this user!
Old 09-08-2005, 12:35 PM
JavaDog's Avatar
Scott
I haven't been able to find anyone local that sells boring heads. Guess I would have to order on online...
I have sme new spade bits laying around, I am dubious, but I will give it a try on some scrap.
I ran as slow as my press will go, and it still chatters like crazy. Even the lightest pressure and it just chatters and screams.
Could it be that the cheap HF 'Drill Master' brand bits are junk?
  #21   Ban this user!
Old 09-08-2005, 12:54 PM
Verfur is on a distinguished road
javadog,
Try shorting the shank on the bit and most likly you will need lots of pressure to keep it from chatering. a 1 inch hole in one pass is a big bite. And is this spade drill at 180 deg. or 118,135 and does it have a pilot? Dont forget the lube.
Good luck
Hope this helps
  #22   Ban this user!
Old 09-08-2005, 03:31 PM
Probably , but I bet that isn't the problem. I'll guess here cuz there's a lot of variables i dont' have info on..... its going too fast and/or too big a cut for the rigidity of the machine. for example, if the pilot is .25 and you are using 1" drill, this a .75 cut - pretty big for a drill pres, esp a light one. think of taking a cut like that on the mill or lathe. those machines are sturdier than a drill press and they'll (depending on size) chatter with a 3/4" cut. I suggestion openning it in stages and make things as rigid as can be.
  #23   Ban this user!
Old 09-08-2005, 03:44 PM
how about an hole saw its rough but it will put a hole in the part with ease.
  #24   Ban this user!
Old 09-08-2005, 09:29 PM
When you are using a big drill in a small drill press sometimes it is better to not use a pilot hole. This seems a bit counterintuitive but the reason is that with a pilot hole the big bit is only touching on the very sharp cutting edge so its digs in one side , catches, jumps out of that side and across and digs in again and you get a horrible mess. Without a pilot hole the center web of the big drill is really only forcing its way into the material, not cutting and this tends to keep the drill centered. It also gives a considerable amount of back pressure and prevents the drill digging in and taking too big of a cut.
If you are cutting steel this most likely will not work because you cannot get enough pressure to force the web into the material. With aluminum it is marginal; a really hard 7000 series alloy will be very difficult but 6061 should be possible with patience and lubrication. Also you can drill a very tiny pilot hole; something with a diameter about the thickness of the web on the big drill or slightly smaller.
