Old 01-18-2011, 10:25 AM
ssutton is on a distinguished road
Holding down Sheet aluminum on router table?
Just completing a 4' x4' machine. Built primarily for cutting out 6061-t6 sheet aluminum no thicker than .063. On a STRICT budget, what are my options for vacuum hold down. I am not going to be cutting fast, so forces should be relatively low.
Thanks to all,
Scott Sutton
Old 01-19-2011, 10:10 PM
-Chris- is on a distinguished road
aluminum hold down
Hi, in our shop we cut alot of al. sheet, we have a vacume table with a MDF SURFACE. We usually spray one side, the side with vynal cover with a easy release contact adhesive made just for that application. Somtimes with small parts we will screw them down after drilling operations then conture the outside. just a couple ideas -Chris-
Old 01-20-2011, 01:51 AM
machiningweasel is on a distinguished road
Tell you the truth, we use a strong double sided tape for alum sheet (max .125 thick) with step downs around outside and it works well, and then it depends how big your sheet is to, just a suggestion
Old 01-20-2011, 02:52 PM
soundoffaudio is on a distinguished road
holddown
you can use tabs when you machine and just cut them apart when your done. it holds the parts together good.
Old 01-20-2011, 03:01 PM
Boltz's Avatar
Boltz is on a distinguished road
what kind of adhesive?
Hi, can you give us some details on the adhesive?
thanks,
-Jim Hart
My main machine: Multicam MG series (MG101) with original Extratech H971 controller, Minarik servo motors, Electro-Craft BRU-series drives, 4KW Colombo. Let's talk Multicam!
Old 01-21-2011, 10:52 PM
contact adhesives
let me say that i mis spoke that the contact adhesive was made spacifically for the purpose of holding parts down to a router table. it is however a product that works very well for us. Our company does alot of vacume bagging of composite parts for airplanes along with alot of landing gear parts and the like We have a large 5 foot x12 ft multicam router and cut Alum sheet and plate up to around 2in thick but mostly thin al sheet we glue it all down with a product called AIRTAC 2 FROM airtechintl.com But Bostic/3M makes some spray adhesives that work well also and it cleans up nicley with aceatone. i hear its a little expensive but i dont worry about that im only one of the machinists. -Chris-
Aluminum sheet cutting on router Funkyjunk General Metalwork Discussion 3 09-18-2010 02:00 AM
Newbie- 4X8 CNC router cutting 3/16 aluminum sheet scorpionracing General Metal Working Machines 2 02-22-2010 03:47 PM
Need help holding and cutting thin Al sheet on router glenneaux General Metal Working Machines 3 08-31-2009 06:43 PM
Need help with holding down aluminium sheet levelzero Work Fixtures and Hold-Down Solutions 10 12-06-2007 03:32 PM
Cutting .020 Sheet Aluminum on a CNC Router Mini-MillX2 General Metalwork Discussion 12 05-01-2007 06:21 PM
