Old 01-14-2011, 10:17 PM
jevs is on a distinguished road
Best way to modify pully and oldham joints....
My VMC had Fanuc DC servo motors on it. The old motors had tapered shafts, and rounded keys in the keyways. I am now going to use TECO AC Servo motors that have a 22mm straight shaft.
I want to know the best method to make the tapered holes in the oldhams and the Z axis cog pulley into keyed straight shaft holes.
The holes need to be for a 22mm straight shaft with a 6mm wide key that sticks up off the shaft 2.5mm. I also need to put a set screw in to hold to the key.
I do have a Lathe and Mini Mill currently to work with.
I was thinking to load them up in my lathe and cut the inside hole out close and then use a 22mm reamer mounted in the lathe drill chuck on the tail. I would then use a broach in my press to make the keyway. Then I would drill and tap the set screw hole.
The only thing bad about this method is that I don't have a broach or a 22mm reamer, and those tools will probobly cost me about $130 give or take.
Anyone have a better and/or cheaper idea or method??
Also what size set screw should I use, and is one set screw good enough?
Thanks,
John
Need Oldham Spider Drawing RTP_Burnsville Benchtop Machines 3 12-29-2010 08:02 AM
spindle to pully play jhead andrewbishop66 Bridgeport and Hardinge Mills 4 06-01-2009 06:56 AM
Diy oldham coupler JBV Mechanical Calculations/Engineering Design 4 05-31-2009 11:19 AM
belt and pully question please help . mjs79 Linear and Rotary Motion 9 10-24-2007 03:13 PM
pully gears and belts for servos replicapro Benchtop Machines 3 07-22-2004 04:23 PM
