Old 01-12-2011, 03:06 PM
neoga34 is on a distinguished road
Using an End Mill on a Lathe
At my work we have a lathe I use frequently. It has a 2MT mount on the tailstock. I would like to use end mills and reamers on there. I'm wondering what's the best way to do that? 2MT end mill holders? 2MT ER-20 or ER-32 type collet holders? What do you think? This would be for general work, nothing high precision or anything.
Old 01-12-2011, 03:32 PM
keebler303 is on a distinguished road
The only time I have used end mills or reamers I just put them in the drill chuck. That was what I had available and it seemed to work just fine.
Matt
Old 01-12-2011, 05:48 PM
End mills if properly modified make great boring tools.
Dick Z
DZASTR
Old 01-12-2011, 07:35 PM
Even without modification they make great boring tools. We use corner radius end mills extensively for finishing internal hemispheres.
Old 01-13-2011, 04:33 AM
lordjw's Avatar
lordjw is on a distinguished road
ER25
Hi!
I use ER25 collets with MT2 collet holder frequently. Only thing you have to be careful of is that your tailstock can eject your collet holder. Usually those have hole and metric or imperial threading and if you are unlucky your tailstock mechanism can get stuck. Be sure to cover the drawbar hole.
FinSlot - Sorvataan 1:32 auton alumiinivanne
Cheers!
Julius
Old 01-13-2011, 06:14 AM
UUU UUU is offline
UUU is on a distinguished road
To avoid hving a holder with a drawbar hole getting stuck in the tailstock, you can get a screw-in tang. I got one from ArcEuroTrade, but other suppliers may stock them.
Old 01-13-2011, 03:57 PM
Ref.#3, I like to grind back most of the "ribbon" on the flutes and bore with the corner of the end mill. Keeps from re-cutting chips and scarring finish bored surfaces.
Dick Z
add: also works on an off-set boring head on a mill. Gets a second life for re-ground undersize end mills.
DZASTR
Just IN- Catching flak at new CNC lathe machining job, can this CNC mill guy 'turn' lathe?! M60Flipper CNCzone Club House 0 11-16-2010 07:18 PM
Should I get a mill or a lathe? (Turning with a mill?) JMcDonald General Metal Working Machines 6 11-02-2008 10:02 PM
New Machine Build- My CNC mill with mini lathe performing CNC lathe operations ryansuperbee General Metal Working Machines 7 08-20-2008 01:06 AM
mill or lathe? mog5858 CNCzone Club House 7 05-28-2008 07:21 AM
Mill and lathe tnc General Metal Working Machines 2 11-19-2006 11:10 AM
