Old 01-07-2011, 01:56 PM
strohkirchw is on a distinguished road
Fly Cutter bits
Anyone know of a place I can buy some 2.5" fly cutter bits for aluminum. I'm not sure if there are any pre-ground specifically for aluminum but I need to order a couple of new ones. Not really looking to DIY on blank bits right now.
Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER) dharschman Toolgrinding & Toolgrinding Machines 3 09-13-2010 12:25 PM
CNC Laser cutter versus CNC Plasma cutter? squale Laser Engraving & Cutting Machines 10 04-26-2009 04:59 PM
Tool & Cutter Grinder and Wire Cutter Plans newport CNC Wire Foam Cutter Machines 1 04-17-2009 04:15 PM
Router bits, End mills v bits bogger44 Commercial CNC Wood Routers 3 12-03-2008 12:06 PM
durability of cnc cutter bits mike_r General Metalwork Discussion 0 05-08-2005 09:44 PM
